ifell 0
QuoteYou know for someone who doesnt fly wingsuits giselle does give you guys a decent run for your money even catches you guys with your pants down every now and again.
Actually I think it's Lauren now
Linas120 0
.....blah blah.....
That is absolutely not truth what you are saying, you probably have no deep knowledge about how these devices work.
....blah blah....
Lauren
It's a pitty I no longer live in UK, it would be fun to meet you in person and discuss all that stuff
kallend 2,106
A skydiver is not a hang glider nor a paraglider.QuoteQuoteYou would do well to pay attention to what others, more knowledgeable than you, are telling you.
So in your little male mind nobody knows anything about a wingsuit and air dynamics to maximize our stay in the air but the wingsuiters themselves? not to mention that our conversation is about electronic flying devices? your comment above is the biggest B****T you said so far.
Noooo, really?
All laws and dynamics is about the same applied to all airfoil without engine, that's why paragliders who never flew Hanggliders knows how a hanggliders works in theory even although they are not able to fly one without a course first. Same applies for a wingsuit, a piece of cloth in an airfoil shape with high loadings using the body and extended arms as a frame, all physics laws and dynamics applied are the same, even although i don't fly one yet is perfectly possible for anyone to know how it works. Now you jumper who know almost nothing about meteorology, air dynamics and the only thing you know is how to control your body in free fall and land a ramair canopy come and tell everyone that you know everything and no one else knows nothing about wingsuits? ignorant much?
Well, Lauren, I do happen to be a licensed glider pilot, a licensed power pilot, a wingsuit flyer and a professor of engineering.
And you are full of it.
QuoteQuoteYes you can zero altitude :) And the next generation will have sound too telling you glide as you fly on top of having HUD :) They just need to know there is a market to spend the money in development...
Jeb you mentioned that next generation will have sound feet back. Will it be software update or we will have to buy second one?
Can this please be answered? By anyone?
crwper 7
QuoteComparing GPS vs Barometric sensor? as debated to death on this topic, they are used for different things, there is no point on comparing them. That's why ALL sailplanes ( including the one on link you posted ) use a barometric sensor for their variometers and not a GPS.
For what it's worth, when I was doing testing for the design of FlySight, I experimented with a barometric altimeter as well. In my experience, a modern GPS is easily as accurate as a barometric altimeter for both altitude and vertical speed. This is not the case if vertical speed is derived from altitude measurements (as is often done with NMEA data), but if vertical speed is derived from Doppler measurements within the GPS receiver, you're good to go.
As far as the reason why variometers use pressure sensors... This is likely based more on cost than accuracy. A GPS provides position information which is not necessary for variometer functionality, but would increase the build price of a vario enormously.
Michael
Michael
Noo I didn't hear this did I? lol GPS's are far cheaper than a barometric sensor, every cheap android phone has a GPS inside.
I fly with my galaxy s3 ( modern GPS and Glonass) phone and it has GPS and baro sensor inside, THERE IS ABSOLUTELY NO CHANCE that the GPS is more accurate for vertical speed than the barometer, on XCSoar application you can choose the data between GPS and Baro sensor and with GPS is way to slow and do not give information at real time like a baro sensor does. you Sink 5 meters in 1 second the baro sensor will says straight away in the same second, the GPS will say 10 seconds later and even not the exact number you sank, instead of 5 it will say 6 7 or 4 etc... totally unreliable for vertical speed.
I know we are all learning with this debates here and nobody knows everything, but I find it AMAZING that some guys here come affirming things that are utterly not the truth. I wonder if wrong information is pass over and over again because others watching this and are unfamiliar with what we are talking may just believe in what is told here and if what is told here is totally wrong they may keep passing the wrong message ahead.
Lauren "Amazed"
BTW I usually teach seminar about GPS's Varios, Baro sensors and flying computers in my flying club. I dont know everything naturally, but I know quite bit in this area.
maretus 0
Mikki_ZH 0
QuoteI read through this thread and then I LOL´d. Seriously. I think you guys should go out and just fly. Without any sensors, barometric or GPS. Just fly and enjoy how it feels.
hahaha, Markus, you must have a lot of time to read all this
but a combination of this thing with an audio voice telling you speed and glide ratio all the time (like a gps), and having some emergency modes like abord, climb, alert, turn left to avoid collision and so on would be nice...
hsbc/gba/sba
www.swissbaseassociation.ch
www.michibase.ch
vidiot 0
Linas120 0
MrCat 0
Will Flight HUD work with Recon’s MOD Live?
No, Flight HUD will only work with custom built software for the MOD Heads-up Display.
One piece of functionality in the Recon MOD Live that would be handy is the "trail map function" - so if there is a little cloud about you could for instance enter waypoints to ensure you can navigate back to your opening point.
the refresh rate on the vertical (altitude) is 10hz,
the refresh rate on horizontal (groundspeed) is only 1hz!
Also these will NOT include any options that the recon mod live have incorporated: no navagation, no buddy tracking, no contour bluetooth connection, no cellphone connectivity. Etc.....
Im waiting for version two, as 1hz is very poor for a gps, and said before the refresh rate of the hud is once every second, I am guessing the reason they did not refresh the hud faster is because the horizontal (speed) will not be able too keep up, and just keep displaying the previous data until the gps refreshes.
B.A.S.E. 1580
Aussie BASE 121
kallend 2,106
QuoteI just got done speaking with recon, Just so everyone knows:
Are you anticipating such a high horizontal acceleration that 1Hz won't be able to follow it?
No, but there are definate advantages to a 5hz system over the 1hz:
1.faster satellite acquisition times
*recon states turn them on a few min before you get in the plane, and they will probably loose signal in the plane and have to re-acquire the signal after you exit the plane approx 20-30 sec
2.better accuracy
*if the gps refreshes 5x faster there will be a difference in accuracy
3.smoother gps tracks for you to interpret.
4.less display lag
*recons hud claims its refresh rate can be faster at the sacrafice of battery life, but the gps horizontal is limited to 1refresh per second.
5. almost real time data
*the difference is 5hz refreshes 5x faster than 1hz meaning every .2 sec it refreshes
almost every new gps for pilots are 5hz
almost every gps for UAVs are 5hz
allot of automobile gps units have moved to 5hz
we usually fly our wingsuits around 100mph forward speed, this equates to 146.6 feet per second.
at a refresh rate of 1hz you can be 146.6 feet behind where the gps thinks you are
when you raise the refresh rate to 5hz you are only 29.3 feet behind where the gps thinks you are.
a difference of 117.3 feet traveled.
the recons calculate glide ratio with two sensors: gps for forward speed and a barometer for altitude. would it not make sense to have these refresh at the same rate so the glide ratio can be properly calculated in real time instead of the barometer refreshing 10X faster than the gps?
B.A.S.E. 1580
Aussie BASE 121
Quoteat a refresh rate of 1hz you can be 146.6 feet behind where the gps thinks you are
You are funny. No GPS tells you where you are, but tell you where you can be with a certain precision. You seem to know a lot about GPS.
QuoteQuoteat a refresh rate of 1hz you CAN BE 146.6 feet behind where the gps thinks you are
You are funny. No GPS tells you where you are, but tell you where you can be with a certain precision. You seem to know a lot about GPS.![]()
i guess you cant read. try again, this time it is in capital letters just for you
B.A.S.E. 1580
Aussie BASE 121
What version two? I quoted their web site and asked Jeb to clarify this a few pages back and never got an answer. According to their website, this is a one time deal and they don't ever plan to offer this product after this one time deal. Personally I am not going to buy something without hearing a few reviews first. Here is the direct quote from their site...
QuoteThis custom package is a Recon Labs project and will only be available for a limited time on labs.reconinstruments.com if we meet the minimum of 250 units within 30 days. We have no plans for retail distribution.
Did they tell you something different?
nope, but with 395 units sold in 14 days it dosent appear to be a niche market to me.
i could be totally wrong, but with the rise in wingsuiting that we have been seeing i dont see them turning away $$$... thats already over $125k just from this project in 14 days....
if the idea works like they think it will, you can only assume they will follow the money, and keep releasing newer updated versions to keep the cash coming in and the customers happy.
B.A.S.E. 1580
Aussie BASE 121
MrCat 0
I think this is only really important IF a nav display was included. As long as it samples the alt and distance travelled at the same time then the glide rate and speed will be accurate. With the features it has I could live with a 1 sec update rate.
On my list of 'wants' I'd be significantly more likely to buy it if I could program waypoints in to follow than a 5hz refresh rate.
crwper 7
Quotethe recons calculate glide ratio with two sensors: gps for forward speed and a barometer for altitude. would it not make sense to have these refresh at the same rate so the glide ratio can be properly calculated in real time instead of the barometer refreshing 10X faster than the gps?
This is most likely due to hardware limitations. 10 Hz barometers are common, inexpensive, and use very little power. An accurate 10 Hz GPS is a lot harder to come by--especially with the antenna size limitations Recon is working with.
Michael
QuoteQuotethe recons calculate glide ratio with two sensors: gps for forward speed and a barometer for altitude. would it not make sense to have these refresh at the same rate so the glide ratio can be properly calculated in real time instead of the barometer refreshing 10X faster than the gps?
Michael
personally i think it has allot more to do with processor speed than the gps.
B.A.S.E. 1580
Aussie BASE 121
The use of these tools should be reserved to advanced pilots, not for beginners, and not forgiving the normal awareness required for any kind of skydive (or BASE Jump).
This would be a first step on improving instruments to aid the ws piloting...
Let's see what technology can do for our sport.
Recon has done the first step...
3,2,1,C-YA!!!
V.
BASE #1075 / BMI #I-002 / PFI #042 / EGI #104
