scotts 0 #1 December 21, 2003 Wondering if there are any Freeflying improvements that can be made to my Talon dom 11/95. My biggest concern is main pin protection. The pin covering flap has two small walrus teeth. I'd also prefer wider leg pads. Thoughts/suggestions? Quote Share this post Link to post Share on other sites
riggerrob 643 #2 December 21, 2003 Wider leg pads can be ordered from Rigging Innovations and installed by any Master Rigger. Why you want wider leg pads is a mystery to me. The narrow, floating leg pads standard on Talon 2 (1997) fit my skinny buttocks better than any other leg pad pattern. It is possible to install wider and thicker Walrus teeth, just make sure the rigger has already done it a few times before. Quote Share this post Link to post Share on other sites
Grumpy 9 #3 December 21, 2003 My Talon is DOM '97 and is pre-Talon2 so I expect the same as yours. The mods I've done to mine are bigger walrus teeth put on the main flap side tuck tabs on the reserve flap a bridle cover added (at the mouth of the BOC) a low profile reserve handle. The rig may not be the newest thing on the dz but it's bullet-proof. Nothing has ever opened or come lose in the last ~700 freefly jumps. PM me if you want more detail on anything. I might even be able to get pictures if you ask nicely Quote Share this post Link to post Share on other sites
scotts 0 #4 December 22, 2003 I'm thinking (bad thing to do) that since most container mfrs offer double wide leg pads, that there must be a good reason for them. Comfort is my guess. Since I don't have skinny buttocks, it's all about comfort. I'll be looking into the larger walrus teeth as well as a bungee strap. Quote Share this post Link to post Share on other sites
fstz28 0 #5 December 22, 2003 newbie question, what the bungee strap for? i also have a talon dom 95. Quote Share this post Link to post Share on other sites
Grumpy 9 #6 December 22, 2003 The bungee ties the two leg-straps together to prevent then sliding down toward your knees when you're in a sit. Later rigs have tabs sewn to the legstraps (check out any newish rig on your DZ) to put the bungee through but yours may not have these. They can be added easily and cheaply. Quote Share this post Link to post Share on other sites
PhreeZone 20 #7 December 23, 2003 Actually a proper fitting rig won't go anywhere on you and you don't need the bungees. Bungees are a band aid solution to a improperly fitting harness.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Grumpy 9 #8 December 23, 2003 Are you sure about that? If you put on your rig, lie on your back, pull your legs up into the sit position (90 degrees to your torso, pointing at the ceiling) and see if you can move the straps towards your knees. If you can, you need a bungee. If you can't, please educate meEveryone who freeflys on our DZ uses a bungee (or clip) regardless of whether or not the rig has been custom built for them. Quote Share this post Link to post Share on other sites
Kris 0 #9 December 24, 2003 I'm sure of it. In 130-ish+ sit-fly jumps on my custom Mirage G3 UNISYN I've never had my leg-straps loosen on me. Even through transitions, etc... My second-hand Talon and a Javelin I borrowed for a while required a bungee, but not my Mirage.Sky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
rainar 0 #10 October 6, 2013 So this was in 2002, any news since then? I'm looking at a 99 talon 2..its cheap and I'm frugal. I want to make it free fly friendly Quote Share this post Link to post Share on other sites
riggerrob 643 #11 October 7, 2013 rainarSo this was in 2002, any news since then? I'm looking at a 99 talon 2..its cheap and I'm frugal. I want to make it free fly friendly .................................................................................... Depending upon its size (smaller being better) that 1999 Talon 2 probably has only a tiny amount of exposed main bridle, but that main pin cover was ... er ... designed before sit-flying became fashionable. I have sit-flown a few times in my Talon 2 (size T5) and never had any problems, but better rigs have been designed since then. Start by looking for a main pin cover that closes upwards. Quote Share this post Link to post Share on other sites
airgord 1 #12 October 8, 2013 rainar, contact RI at info@rigginginnovations.com. We can make it freefly friendly. Quote Share this post Link to post Share on other sites
