MathmatiC 0 #1 December 23, 2003 Have any of you guys either had, or seen a X-fire 119 in a Javelin Odyssey RSK.5? I talked to Sun Path already and they said it would fit, but would be uncomfortable. Just curious as to your opinions, and experience on the subject. An RSK.5 holds upto 120 reserve and 107 main. Thanks, Matt *** Quote Share this post Link to post Share on other sites
Hooknswoop 19 #2 December 23, 2003 I had an XRS and there was no way anything over the PD-113R would fit in the reserve container. I knew someone that had a Stiletto 107 in their XRS and the D-bag finally split open. I'm not sure how much larger the RS is over the XRS it replaced. Derek Quote Share this post Link to post Share on other sites
GroundZero 0 #3 December 23, 2003 QuotePost: Have any of you guys either had, or seen a X-fire 119 in a Javelin Odyssey RSK.5? I talked to Sun Path already and they said it would fit, but would be uncomfortable. Just curious as to your opinions, and experience on the subject. An RSK.5 holds upto 120 reserve and 107 main. Thanks, Matt It holds a 107 main... and you're asking if a 119 will fit... NO... That canopy is measured well larger than a 107.... (and they use the "different" measuring system.) Quote Share this post Link to post Share on other sites
MathmatiC 0 #4 December 23, 2003 Quote That canopy is measured well larger than a 107.... (and they use the "different" measuring system.) Could you expain the different measuring system. I Have never heard of it. Thanks, -Matt- R.P.G.G. *** Quote Share this post Link to post Share on other sites skycat 0 #5 December 23, 2003 Icarus uses the same measuring system as PD, so their canopies are bigger than percisions. PIA needs to set a standard. btw....X-fires pack bigger than say a Stiletto of the same size due to the extra material on the nose. The X-fire1 packs up bigger than the X-fire 2 due to having all the D lines (ie. sabre) where the 2 has 2 less like the Stiletto.Fly it like you stole it! Quote Share this post Link to post Share on other sites skydogs 0 #6 December 23, 2003 I used to put a Sabre 120 in my RS1. It was tight , but it was in there.. Not uncomfortable and looks fine. Now I've got a XAOS 98 in there and it fits about the same. All with a PD113.. Edited to PD113 Quote Share this post Link to post Share on other sites PhreeZone 20 #7 December 23, 2003 PD133? You mean a PD 113, 126, or 143?Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites diablopilot 2 #8 December 24, 2003 QuotePIA needs to set a standard. They have. Not many manufacturers (who are mostly PIA members) liked it.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites MathmatiC 0 #9 December 24, 2003 Hey guys, Thanks for your input. Matt *** Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
