Faber 0
QuoteAre other people prepared to take pin rigs this height or lower ?
yes i have been in 141ft by my pin rig,and i will take it as low as i would dare to jump anyway.
Stay safe
Stefan Faber
BASE813 0
george!
nice to see ya!! One of the reasons I am buying a pin rig is that I am freefalling 210ft upward regularly.............
At these heights I would rather a pin then a velcro............
the pull forces are something like 20lbs for velcro and 12lbs for pins (but pins have more inconsistancy due to pack jobs)
to be honest when I am taking delays where I am under canopy at sub100 I would so much prefer a pin rig....................
I have watched a pin V velcro off the same 220ft tower with similar delays and similar PC's and the pin opened a lot heigher!
mate pin is the future for the objects we are jumping!!!
Cool
http://georgechurchill.blogspot.com
Twoply 0
George!
Send me an email!
Mike!
Pringles is a cross-dresser!
Send me an email!
Mike!
Lee846 0
I use 2-pin rig Atmosphere for low altitude/ hand held jumps. It works normal.
Several russian guys prefer another pins for low altitude jumps. There are the yellow cable pins (like the cut-away cables on the skydive rigs). They considered, that it may be several position for metal pins than the way out of the loops would be something hard and takes more time.
Between two evils always pick theone never tried
robibird 3
I can understand their concern, but in order to avoid possible hesitation it is very important to place both pins in the middle of the loop.
Also, pin orientation should be bottom to top.
Regards
Regards
Robert Pecnik
robert@phoenix-fly.com
www.phoenix-fly.com
www.phoenix-fly.com
Hajo 0
Hi there, some info of how we do that in germany. we have tested several things like tuckin´ the bridle under the right flap (as described in the other posting) but what our association recommends is: install 2 small pieces of velcro on the bridle and at the container (right flap). this will cover the fluttering of the bridle during hand held jumps (like the velcro does at velcro-closed containers). it also makes sure, that the bridle routing is correct and you can check it at any time prior to exit as you like. it also prevents pin extraction from checking the bridle (done by stretching your arm out), because the pulling force is slightly covered by the velcro tabs. We made this a must modification for our legal gear and it works pretty good.
With sufficient thrust,
pigs just fly well
pigs just fly well
bor 0
Quotepin orientation should be bottom to top.
Hej robi, what do you mean with bottom to top? Pin eye on bottom? Why is this better?
hvala
Having never jumped a Pin Rig, I was a little bit apprehensive about using a mate’s pin rig for the first time, off A 225ft A the other day. We didn't jump cause of the wind.
Cheers
George
