theskydiveguy
Z1 Visor Question
Take the liner out, there's 2 kinda screws on the inside. With a screwdiver (or equiv) on the OUTSIDE (to stop it spinning), turn the inside ones 90 degrees and you should be able to take the bolts out. Make a note of how the came out you can put em back later ;). Do the same on the other side. (I'm doing this from memory so take it with a pinch of salt ..)
____________________
Say no to subliminal messages
Just like the Monkey said - I think a 12 or 13mm wrench helps hold those little nuts on the inside. There's a spring in there, too, so beware. Just a quarter turn, don't force it, and it'll all be good. I put a new face-plate on mine once a year, takes about ten minutes start to finish.
Z-1s Rock.
Easy Does It
