boachanoff
tracking pants
I'm considering buying a tracking pants,but I'm wondering whether the belts of the harness to be under or above the pants.Is there difference in performance and if so are the differences significant.
regards:Plamen
see:
http://www.phoenix-fly.com/pfpants.htm
Quote:
Phoenix Fly Pants are designed to be worn over your harness leg straps, thus creating an even larger and smoother surface.
Cheers,
Michael
Michi (#1068)
hsbc/gba/sba
www.swissbaseassociation.ch
www.michibase.ch
Way better performance over the harness.The air can flow throughout the pants(in escense like a wing suit).
http://freakboy066.tripod.com/
I had a look at the pressurized pants here in Norway, and are willing to give them a try. But I could see some few things that will not make them fly as good as the Phoenix pants! bigger surface is not always better for distance and speed!
I can promise you the Phoenix fly pants is the best I have seen so far!
www.friluftslek.no check it out if you have not seen it before!
I will let you know if I believe other pants fly better than the poenix! I like there are more than one who make pants, it makes the producers more creative!
if you don´t try, you can´t say. give the pressurized suit 20+ jumps and read what they write about how they work. soon you will realize, that it´s NOT bigger surface that makes them fly...
DRU
