JerryBaumchen 1,436 #1 November 10, 2011 Hi out there in USA-Land, I need to replace my garage door opener. I've owned two, both Genie's that I installed myself. They worked fine: #1 went with the house when it was sold, #2 just died somewhat after ~15 yrs. I was in Lowe's and they carry both Genie & Chamberlain. Anyone using Chamberlain and what would you say about them? I do prefer a screw-drive model but have been told that the belt drives are better ( or so they said ). Thanks in advance, JerryBaumchen PS) No, this is not asking about legal or medical info. Quote Share this post Link to post Share on other sites
ltdiver 3 #2 November 10, 2011 I'd go with a professional grade. Those sold at Home Depot and Lowes are lower grade that come in sections and aren't as sturdy. Had my last one for 30 years and just traded it out because it was time. It was still working fine, though. (upgraded my garage door and opener at the same time) Don't tell me the sky's the limit when there are footprints on the moon Quote Share this post Link to post Share on other sites
lowapproach 0 #3 November 10, 2011 No experience with those two, but I have this one and love it. The battery backup alone is worth it, but it is also super quiet. http://www.liftmaster.com/consumerweb/pages/productmodeldetail.aspx?modelId=2387 Quote Share this post Link to post Share on other sites
JohnMitchell 16 #4 November 10, 2011 I've had the chain drive, screw drive and belt drive. I think I like the belt drive best. Very quiet and no grease. Quote Share this post Link to post Share on other sites
VideoFly 0 #5 November 10, 2011 It is typical for garage door openers that age to have the two plastic gears strip and it is surprisingly easy to replace them for about $35.00 in parts. The gear change is probably easier than changing the hole unit because everything but the gears stay in place during the procedure. If you open the case and see a pile of plastic powder, you will know that’s the problem. There are lots of directions on lineincluding Youtube videos showing the procedure. Quote Share this post Link to post Share on other sites
NewGuy2005 53 #6 November 10, 2011 QuoteIt is typical for garage door openers that age to have the two plastic gears strip and it is surprisingly easy to replace them for about $35.00 in parts. The gear change is probably easier than changing the hole unit because everything but the gears stay in place during the procedure. If you open the case and see a pile of plastic powder, you will know that’s the problem. There are lots of directions on lineincluding Youtube videos showing the procedure. +1 I've made this repair myself and it's not that hard. Also, a LOT cheaper than replacing the closer. Quote Share this post Link to post Share on other sites
Krip 2 #7 November 10, 2011 Hi Mr Baumchen Rsearch this onehttp://www.wayne-dalton.com/DirectDrive.asp Quote Share this post Link to post Share on other sites
JerryBaumchen 1,436 #8 November 10, 2011 Hi Fly, If that was the problem. The control board is on the fritz and they do not make replacement boards for it any longer. JerryBaumchen Quote Share this post Link to post Share on other sites
JerryBaumchen 1,436 #9 November 10, 2011 Hi Krip, Quote Rsearch this one Did; it says it only works on certain W-D models of doors. JerryBaumchen Quote Share this post Link to post Share on other sites
iowa 0 #10 November 10, 2011 Chamberin is made by Liftmaster, or vise versa, both are good. Someone mentioned getting the better, aka heavy duty, from a door company. Highly recomended. The big box stores usually carry the cheaper lines and I've found the cost not much more to cash and carry from the pro dealers. Keith ''Always do sober what you said you would do drunk. That will teach you to keep your mouth shut.'' - Ernest Hemingway Quote Share this post Link to post Share on other sites
Krip 2 #11 November 10, 2011 Quote Hi Krip, Quote Rsearch this one Did; it says it only works on certain W-D models of doors. JerryBaumchen Hi MR Baumchen Only certain models of W-D doors or We had a autorized W-D installer come out to check out our place. It was probably 10 yr's ago. He never mentioned replaceing the doors. Just removeing the killer springs and crap. Might have his bid in my files somewhere. OTOH time change cost of energy goes up, there's some nice energy efficient light weight garage doors around these days. We watched a builder/ neighbor put in his W-D system from scratch, all by his lonesome. The installation instruction are available on line. To tension the system he just used a ratchet. All we did was remove the 20 y.o.openers and replace them with the 60 y.o. model Quote Share this post Link to post Share on other sites
chutem 0 #12 November 10, 2011 Quote Hi Krip, Quote Rsearch this one Did; it says it only works on certain W-D models of doors. JerryBaumchen[/reply This unit works on all models. http://www.youtube.com/watch?v=1C-Bxifv2Pk James Quote Share this post Link to post Share on other sites
JerryBaumchen 1,436 #13 November 10, 2011 Hi James, QuoteThis unit works on all models. If only I had that available. And thanks; a little levity is always a good thing. JerryBaumchen PS) And for all of you: Thanks for the input. I have found a 3/4 HP belt drive Genie that I am drifting towards ( Thanks, John Mitchell; you convinced me ). Now just need to see if it will accept all of the custom controlling that I have done to my current/non-working device. Quote Share this post Link to post Share on other sites
Phillbo 11 #14 November 10, 2011 Make sure the 3/4 hp unit is not made for a taller door than you have... They are typically made for RV doors and the track is much longer so you'll have to move the mounts ... I'm assuming you have the typical residential door. Quote Share this post Link to post Share on other sites
danornan 79 #15 November 10, 2011 After you get the opener, get a Flash2Pass remote. I installed on on my motorcycle and just hit the high beam to open or close the door. Don't have to fool with a remote control. You can uses multiple vehicles.Dano Quote Share this post Link to post Share on other sites
theplummeter 15 #16 November 11, 2011 The Genie line has one major problem that seems to have infected all of their lines in which one of the major printed circuit boards shorts and becomes unrepairable. It usually starts with not recognizing a remote and eventually disables the unit. There are three garage door installation businesses in town here (I've worked with them all as a new home construction subcontractor) and each of them have moved into the Liftmaster Chamberlain lines. Quote Share this post Link to post Share on other sites
