cgriffith
First rig New or Used???
I am a new skydiver with 110 jumps and I am looking to buy my first rig. I do not know if I should buy something used or new? I do not want to spend $5000 on new gear then want to down size in a few months :(
I am 5'7" 170lb and I have been jumping a Pilot 188 for the past 70 jumps.
Should I go new or used??? Thanks :)
I've bought most of my gear over the years used. If you choose carefully, it's like getting a discount, and you can use the savings to jump.
Ask to try things on to see what fits; you're not an uncommon size. If you turn out to be hard to fit, then you can consider new. Whatever you get, if it's used, get it inspected by a competent rigger, including a tensile strength test on a used main. Well taken-care-of ones can have problems too.
And buy something that's right for jumping NOW. Don't buy something that you'll "downsize into." Because it'll be a pain in the ass to pack, and will encourage you to downsize at the first possible moment, rather than when it's a really good time to.
One more thing -- if that Pilot isn't yours, a used main is FAR easier to pack than a spankin' brand new one that's slippery as ball bearings.
Wendy W.
You answered the question yourself.
If you don't want to spend over $5,000.00, then you will most likely want to look for good used gear.
There are plenty of jumpers who do buy new gear right out of the gates. Lucky you. That means there is a lot of good quality used gear on the market! ;)
If you PM me your measurements, I can look around here for a match. Any questions or concerns you might have in your quest can be directed to me as well.
Good luck!
Peace and Blue Skies!
Bonnie ==>Gravity Gear!
My first rig was totally used.
My second rig, which will be complete mid Feb will contain my current Cypres, a used main and reserve but the container will be new.
For your first rig, i would definitely go with used. There is alot of good stuff out there. But if you can't find a container that fits you well, you could do like I did and just buy that part new.
Why yes, my license number is a palindrome. Thank you for noticing.
I'd say to definitely get used. You said it yourself that you don't want to buy and then downsize a (relatively) short time afterwards.
Another factor to consider is you'll probably have a better idead of exactly what you want once you've got a couple hundred more jumps.
You can buy used, jump it for a couple hundred jumps (or more), and then sell it for close to what you paid for it.
There are battered women? I've been eating 'em plain all of these years...
All good advice, but if I could add something, buy used because your landings aren't going to very gracefull for a while and why spend a ton of money on something new only to scrape it up and reduce its resale value
This is what i was told when i bought my first set of gear and it's what i continue to tell others who are looking to buy.
Advertisio Rodriguez / Sky
I wanted used... But I could not find the "right" rig for me. So I bought new, but on killer end of year sales for "off the shelf" items - so I paid what some people pay for used but I got new.
But - the time it takes to make a new container = rental $$$. That made buying new much more expensive...
Here is my thought.... Buy quality, buy the right rig, regardless of new or used. It is after all, your life, that the equipment saves every time it is used. A ER trip = $4,000+, so buying a rig that is right for you in the long run will be less $$$ than buying something a few $$$ cheaper that is not right for you.
T.
