nitro98
Nitro and its lines , lines have problem?
Hi,
I have a question about nitro or nitron in the USA.
Before I bought a nitro one German guy told me bad things about the lines of nitro, however I really like the canopy and I got one used one with a new line set. After only 30 plus jumps there was problem with the break lines, it was damaged. my questions,
the lines of nitro is not good? I had a lines twist but not a bad one can it be because of that. Is it safe to jump this canopy ( I love the way it flies) My rigger chanced the breaks with a micro lines but I did not try it yet is it ok? If you can help me It would be great.
Micro line (I assume you mean spectra) is very strong and durable, but it is not a good choice for lower control lines for two reasons. First, there is significant shrinkage of control lines made of spectra. I have seen as much as an inch per hundred jumps on some canopies. Secondly, spectra has no elasticity (stretch), so a hard opening can result in a broken control line made of spectra. The NITRO currently uses dacron for the lower control lines, but we use a 750 lb. line instead of the 400 lb. that has been mentioned earlier in this thread. As far as the suspension lines themselves, the Technora (HMA) is a wonderful line and I have seen many canopies with well over 1000 jumps on the original lineset.
Never trust what any German guys tells you...:P
And I have over 1400 jumps on my HMA lines now. Never have broken any, but it is do for a reline soon just in case. ;)
Be safe.
Ed
www.WestCoastWingsuits.com
www.PrecisionSkydiving.com
