warpedskydiver 0 #1 February 12, 2010 http://www.white-rodgers.com/wrdhom/common/ptech/hydronic/info_list_zone.htm#1311-102 I have two zones which must be slaved together, they were originally set up that way. I have one set up perfectly and it is connected to it's own thermostat. I have the other set up to the thermostat, but need to know how to connect the zone controls, i.e. which connection points from one to the other. Quote Share this post Link to post Share on other sites
stitch 0 #2 February 12, 2010 Bolas comes equipped with zone controls ? Go figure. The things you find out about on the innerweb. "No cookies for you"- GFD "I don't think I like the sound of that" ~ MB65 Don't be a "Racer Hater" Quote Share this post Link to post Share on other sites
warpedskydiver 0 #3 February 12, 2010 Anyone with this type of setup can just take a picture, that would help immensely. Quote Share this post Link to post Share on other sites
Brains 2 #4 February 13, 2010 I don't know jack shit about boilers but have zoned many central ht/ac systems. Why would you want two separate zones slaved together? On most zone motors (instead of valves) you can run from the stat to term. 1 on one motor and from there to term. 1 on the second motor and have them work together that way. Same with terminals 2 and 3 etc. Most of them can only run about three motors/valves in series without any problems. Is this what you mean? Of course by doing this, you don't need two thermostats, only one. Never look down on someone, unless they are going down on you. Quote Share this post Link to post Share on other sites
tdog 0 #5 February 13, 2010 Are you using the 3 wire valves? On the installation instructions on the link provided, which way is the single valve wired that is "set up perfectly"? Transformer and thermostat only, or a controller too??? There are many ways to initially wire the setup, so before it can be answered, need to know what you got.... Quote Share this post Link to post Share on other sites
