NewGuy2005 53 #1 May 28, 2009 About to buy a full face helmet that will be used mostly in the summer. I've never bought a street bike helmet before. Any pointers? Quote Share this post Link to post Share on other sites
downwardspiral 0 #2 May 28, 2009 Make sure it's DOT and Snell approved. and remember this saying.... $10 helmet for a $10 head.www.FourWheelerHB.com Quote Share this post Link to post Share on other sites
Kong 0 #4 May 28, 2009 DOT approved, don't worry about Snell. A decent helmet will run you around $200 minimum. Quote Share this post Link to post Share on other sites
jtnesbitt 0 #5 May 28, 2009 Check the ratings. Some are only DOT approved, personally i went with Snell approved. Vents are important. Not only to keep cool when its warm but more importantly to help with fogging when it's night or cool. A good fit is key. Also, if you plan on trying a few on take a pair of sunglasses with you when trying them in case you ever need to ride in shades. I'm not a fan of tinted visors as you cant use them at night and they scratch."If this post needs to be moderated I would prefer it to be completly removed and not edited and butchered into a disney movie" - DorkZone Hero Quote Share this post Link to post Share on other sites
NewGuy2005 53 #6 May 28, 2009 QuoteMake sure it's DOT and Snell approved. and remember this saying.... $10 helmet for a $10 head. I wish my head was worth that much!! Quote Share this post Link to post Share on other sites
downwardspiral 0 #7 May 28, 2009 QuoteDOT approved, don't worry about Snell. A decent helmet will run you around $200 minimum. You can get a DOT/Snell approved helmet for $100. Nothing wrong with wanting/having a higher standard than DOT. Snell Approved Helmets The Snell Memorial Foundation (SMF) was formed in 1957 after William "Pete" Snell, a race car driver, died from massive head trauma. he sustained in a racing accident. The non-profit organization focuses on learning more about the components of head injuries, and how to prevent them by using helmets. Through their research the foundation has developed a standard for approving helmets that is continually tested and updated every five years. There are two key differences between a DOT- and Snell-approved helmet. First, is the testing standards the helmets go through, and second, is the verification of the results. Although their testing process is very similar, SMF requires their certified helmets to withstand a greater impact and absorb more force than the DOT standards. Both standards drop the head forms on flat and hemispherically shaped anvils in order to simulate different types of impacts. However, Snell also uses an edged anvil that specifically tests the integrity of the helmet's shell. DOT and Snell test each helmet two times at four different impact zones. DOT drops their helmets from a 6-foot height on the flat anvil and from a 4.5-foot height on the hemispherical anvil. Snell on the other hand, drops the helmets from a 10-foot and 7.5-foot height on both anvils, which simulates a more severe impact. While there's no guarantee a DOT-approved helmet has actually been tested, the purchase of a Snell-approved lid ensures that the product has been evaluated under scrutiny. A Snell-certified helmet also meets and exceeds the DOT standards. http://www.leatherup.com/g/Snell-Approved-Helmets/90.htmlwww.FourWheelerHB.com Quote Share this post Link to post Share on other sites
shropshire 0 #8 May 28, 2009 Obvious really ... but make sure that it fits correctly. Buy a repitable brand (not some cheap knock-off because it looks cool) Make sure that it's a relatively current model, so that you can still get replacement visors. (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
wmw999 2,452 #9 May 28, 2009 I'm going to go with fit, along with the standard approval(s). Look at DOT and Snell and decide if you need both. But get a helmet that fits all of your head snugly if possible (i.e. it's not tight front to back and loose side to side, or vice versa). Some helmets are for rounder heads than others. I wear an XL Oxygn for skydiving, because of head shape. But in HJC (a creditable, but not top-end brand), I wear a medium, because it fits so well. Which means less shifting of the helmet if I do go down. OTOH, my husband wears an Arai, because his head is narrow side to side. I used to have a Shoei, and it pressed against my forehead, making a red spot. The conventional wisdom is that you should wander around the store wearing the helmet for 20 minutes to check it out for major pressure points and comfort. Here is a short article about picking out a helmet. Sound like overkill? You'll be wearing this as long as you're wearing the bike, most likely. Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
Hooknswoop 19 #10 May 28, 2009 50% of DOT Approved fail the DOT test when they are actually tested by an independent lab. In order to receive DOT approval, the manufacture must believe the helmet will pass the test, they do not have to actually test the helmet. You can do a search for the DOT test results. DOT means nothing. Get a SNELL certified helmet. http://www.nhtsa.gov/cars/testing/comply/fmvss218/2007s218.pdf DV Quote Share this post Link to post Share on other sites
EvilEagle 0 #11 May 28, 2009 Don't spend $9k on a bike and $100 on a helmet! A good lid will cost some cash. I only ride with Arai helmets now. I've owned AGV, Shoei, HJC, Nolan, Bieffe and a few others. I have a noggin that fits best in Arai's - that (along with their safety record) is enough to keep me in an Arai. They are also (IMHO) the best vented helmet. Quote Share this post Link to post Share on other sites
LaRusic 0 #12 May 28, 2009 Second for Shoei, i also like Icon helmets, they fit my head amazing.The Altitude above you, the runway behind you, and the fuel not in the plane are totally worthless Dudeist Skydiver # 10 Quote Share this post Link to post Share on other sites
jtnesbitt 0 #13 May 28, 2009 +1 for Icon, i love their helmets gloves and jackets. Great fit, great quality, awesome protection, and of course the most important factor...style "If this post needs to be moderated I would prefer it to be completly removed and not edited and butchered into a disney movie" - DorkZone Hero Quote Share this post Link to post Share on other sites
rlucus 0 #14 May 28, 2009 I ride with a Scorpion EX-700 It's my third helmet and I love it leaps and bounds over HJC and KBC... Edit: to concur that DOT doesn't mean sh*t, go with SNELL Quote Share this post Link to post Share on other sites
ryoder 1,590 #15 May 28, 2009 Quote 50% of DOT Approved fail the DOT test when they are actually tested by an independent lab. In order to receive DOT approval, the manufacture must believe the helmet will pass the test, they do not have to actually test the helmet. You can do a search for the DOT test results. DOT means nothing. Get a SNELL certified helmet. http://www.nhtsa.gov/cars/testing/comply/fmvss218/2007s218.pdf DV Whoa!!!A posting by Hooknswoop!!! I'm going to save this; These are so rare these days, I just know it will be a valuable collectors item!"There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
skyjumpenfool 2 #16 May 28, 2009 Fit is everything! Don't listen to the salesman like they're God! You have to like the fit. They'll tell you it has to be really tight (and it should be). But, it shouldn’t be so tight as to give you headaches. Do some research on helmet fit, and try them on to see which one is right for you. http://www.motorcyclehelmet.com/helmet_fitting_guide.html Also, I always recommend buying an extra shield. They’re hard to find two years down the line and you’ll probably get scratches in the original soon enough. Blue skies and twisted highways...Birdshit & Fools Productions "Son, only two things fall from the sky." Quote Share this post Link to post Share on other sites
LongWayToFall 0 #17 May 28, 2009 I ride with a shoei, and like it very much. As others have said, each manufacturer has a different shape, so try on the major brands and see what fits best. Shoei, Arai, Icon, Suomy, all very good lids. My bro has a Suomy that was very expensive ($700) (He works in a motorcycle apparel store and knows his shiznit) and it is a NICE helmet. Incredibly light. Anyways, figure out which brand works for you, and then get the model that matches your price. As others have said, more vents is something you can't add later, but I can bet you will want. Quote Share this post Link to post Share on other sites
Cuse313 0 #18 May 28, 2009 here is an article about helmets. Long but interesting. I would suggest everyone who is going to wear/buy a helmet read it, including those who already have one. http://www.motorcyclistonline.com/gearbox/motorcycle_helmet_review/index.html Quote Share this post Link to post Share on other sites
NewGuy2005 53 #19 May 28, 2009 Excellent advice everyone. Thanks! Quote Share this post Link to post Share on other sites
skyjumpenfool 2 #20 May 28, 2009 Oh, and one last really important thing... Good choice on deciding to wear a helmet!!Birdshit & Fools Productions "Son, only two things fall from the sky." Quote Share this post Link to post Share on other sites
warpedskydiver 0 #21 May 28, 2009 QuoteCheck the ratings. Some are only DOT approved, personally i went with Snell approved. Vents are important. Not only to keep cool when its warm but more importantly to help with fogging when it's night or cool. A good fit is key. Also, if you plan on trying a few on take a pair of sunglasses with you when trying them in case you ever need to ride in shades. I'm not a fan of tinted visors as you cant use them at night and they scratch. Make sure there is room for a balaclava for when it is cold or you have a shaved head. Quote Share this post Link to post Share on other sites
warpedskydiver 0 #22 May 28, 2009 I have an AGV Sukhoi that needs relining, it is so good I will make the effort to do so. Other helmets in the same class now cost $700 Quote Share this post Link to post Share on other sites
AggieDave 6 #23 May 29, 2009 I've been riding a BMW 1150RT for the last few weeks and riding with a modular full face. I really am not a fan of full face helmets (even though they offer much better protection), but I like the modular since if I get hot in traffic I can lift it. It makes life much more enjoyable. Now I'm even thinking about buying one to ride with on my personal bike in the winter (the helmet, not the BMW, I can't afford the BMW even though its a great bike). --"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
normiss 801 #24 May 29, 2009 meh.... all about personal choice I suppose. I ALWAYS wore high quality full face lids when I rode the donor cycles. Yesterday crossing the state line from GA to FL, I couldnt' wait to lose that lid. I LOVE the free feeling of no helmet. Much like safe sex I suppose. Damn does it feel good!!! If a bike wreck is severe enough that the helmet will keep me alive, maybe I prefer to not survive. I've laid 'em down twice at fairly high speeds without a helmet. Been fine both times. Sudden impact? Helmet won't help. I do fully support people in their own choice.The OP wants a quality helmet. Much good advice given to that end. Quote Share this post Link to post Share on other sites
FlyingJ 0 #25 May 29, 2009 Fit Fit Fit. If it doesn't fit you won't wear it and will have wasted your money anyway. I have a HUGE and oddly shaped head and literally tried on every XL helmet for sale two counties in every direction. Finally went with an Arai. It cost me an arm and a leg, but I knew that I just wouldn't wear it if it didn't fit.Killing threads since 2004. Quote Share this post Link to post Share on other sites
