isaiah85 0
QuoteThey do both. PD has a competition lineset not available to the public. Packing beside Jay, his lines are noticably longer than are mine (granted he was jumping a 103 compared to my 96).
Lengthening the risers in addition to increasing the recovery arc also gives you more control range that simply adding line length does not.
Canuck
The competition line set and RDS will be available in November, yes, the same canopy the Factory Team and Team Fasttrax jump. The only thing is the line set only has about a 100 jump life. It makes a big difference but it's pretty expensive.
The thicker HMA (500) will also be available, has a longer life and is still a lot thinner than Vectran.
Later,
Isaiah
JerryBaumchen 1,354
Mark,
Any update on the shipping of the 269; or are you still out cleaning up after Katrina?
Jerry
Jerry
My risers are very long, maybe 32", but then again I am 6'9 with a 38" sleeve length. I took the risers that came with my rig (they had 500 jumps+ on them at the time), and picked the stiching off (the stiching that holds the folded over section that creates the line attachement point) . I then cut a piece of type 17 webbing that extended the riser to the desired length and overlapped the original by 4". Using a Brother home machine I ran 3 rows of a tight zig-zag stich over the overlapped part. Works great, costs little, but takes a little time.
The first pair I did this with I made them too long and had to re-do them. I have 2 pair like this and each set of risers has well over 1000 jumps on them. If I had to do it again I wouldn't pick the stitches, I would cut them off and just attach a new piece of webbing, and not overlap on both sides.
YMMV, but its worked well for me.
Cya.
Cya.
If you choose to go with Mirage risers we can make them any length you want and the price tag is $110.00 for standard and $135.00 for stainless. Any other questions feel free to contact me at ward@miragesys.com
Canuck
