Twerky 0 #1 October 11, 2005 Will a Barigo 12000 foot altimeter still function above 12000? i can see that i wouldnt knom my altitude above 12000...but i just want to make sure that it isnt going to throw off the calibration or damage it. Quote Share this post Link to post Share on other sites
Peej 0 #2 October 11, 2005 I don't see why not. If i go above 12000 with my Alti III i just think of 0 as 12 000, 1 as 13000, 2 as 14000, 3 as 15000, etc. Then once you're below 12000 everything works as normal. Advertisio Rodriguez / Sky Quote Share this post Link to post Share on other sites
Twerky 0 #3 October 11, 2005 i understand that... the problem i am having is that this alt is not configured like the clock style altimeters. it looks more like a speedometer on a car and the 12 isnt the same as 0. Quote Share this post Link to post Share on other sites
billvon 3,070 #4 October 11, 2005 Depends on the altimeter. Most will 'wrap around' and go to 18,000 feet or so. After that they will stop incrementing but will not generally be damaged. Quote Share this post Link to post Share on other sites
Peej 0 #5 October 11, 2005 Guess i jumped the gun by ASS-uming they were the same Advertisio Rodriguez / Sky Quote Share this post Link to post Share on other sites
IanHarrop 42 #6 October 11, 2005 Quotei understand that... the problem i am having is that this alt is not configured like the clock style altimeters. it looks more like a speedometer on a car and the 12 isnt the same as 0. I'm curious.. is there any way you can post a picture of the device in question?"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
dragon2 2 #7 October 11, 2005 It works fine, it just won't tell the the attitude much, beyond "higher than 12k" ciel bleu, Saskia Quote Share this post Link to post Share on other sites
dragon2 2 #8 October 11, 2005 It's just an alti. http://www.parachutecase.nl/theshop/artikel/instrumenten/images/small-barigo1.jpg ciel bleu, Saskia Quote Share this post Link to post Share on other sites
IanHarrop 42 #9 October 11, 2005 Thanks, now I understand... there is that undetermined space between 12,000 and 0"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
kingbunky 3 #10 October 11, 2005 if you look closely, you'll see that it says 'holy crap you're high!' in tiny letters in the gap."Hang on a sec, the young'uns are throwin' beer cans at a golf cart." MB4252 TDS699 killing threads since 2001 Quote Share this post Link to post Share on other sites
IanHarrop 42 #11 October 11, 2005 Looks like the perfect altimeter for a Cessna dropzone... never going to get to that holy crap area."Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
gemini 0 #12 October 11, 2005 Although I have not seen one in years, there was a brand that had a stop above 12K. I would suspect it could be damaged by going to higher altitudes since the pressure would cause the needle to push harder and harder on the stop pin. I have been to 30.5K with my 6 year old Altimaster and it works fine. Blue skies, Jim Quote Share this post Link to post Share on other sites
bob.dino 1 #13 October 11, 2005 To give you a definite answer: yes, it will. The needle will continue to climb without problems. I think of 0 as approximately 13,000ft. Quote Share this post Link to post Share on other sites
skydiverton 0 #14 October 12, 2005 QuoteThanks, now I understand... there is that undetermined space between 12,000 and 0 Very simple. The barigo is a german brand of altimeter. In germany they jump in meters (like in france). A barigo with a meter scale will show no space between the 0 and 4000meter. To sell this altimeter to the feet-jumping community the most simple modification is remove the meter-scale and add a feet-scale, without modification of the inside. (If you want to swap from meter to feet simply buy a $5 feet-scale) As 4000 meters is a little more than 13000ft you will see a gap between 12000 and the 0. As a barigo owner I can assure you the altimeter works at least to 17000ft. Probably higher but I never jumped higher than 17000ft. Have the same barigo for at least 10years. Still functions good. ++++++++++++++++++++++++++++++++++++++++++++ Using your droque to gain stability is a bad habit, Especially when you are jumping a sport rig Quote Share this post Link to post Share on other sites
packerboy 3 #15 October 12, 2005 I own a Barigo and have checked it against other altimeters in the plane w/ me. 0 seems to be about 13,500ft. -------------------------------------------------- In matters of style, swim with the current; in matters of principle, stand like a rock. ~ Thomas Jefferson Quote Share this post Link to post Share on other sites
IanHarrop 42 #16 October 12, 2005 You're right. I did the on-line conversion thing and 4000 meters is about 13,123 feet Thanks for defining that "undetermined space" "Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
