QuoteThere are some more experienced people out there who thought and still think the ford pinto was a good car....
HEY! I had a '74 Pinto (ugly-as-sin brown), and I thought it was just fine....
But then again, I also liked my '75 Vega hatchback...
Steve
The definition of insanity is to keep doing things the same way, but then to expect different results. -Einstein
Elisha 1
QuoteFrom PD’s web sit.
Straight Flight at full Glide: The Sabre2 and the original Sabre both fly at about the same airspeed, but the glide angle of the Sabre2 is a bit flatter. You may notice the Sabre2 gives you better penetration when flying into the wind, and carries you farther when flying with the wind at your back.
According to PD the glide is better with Sabre2
But like you said what you are used to can influence your perceived feel for the canopy.
mjo,
Can you explain "better penetration" but a flatter glide? To me, a flatter glide would imply less penetration, not better. If winds were such that I was barely moving forward or standing still, I was told that fronts (risers) would help penetrate to get some progress.
friday999,
Sabre1 better....you're just weird. I have no problem with my Sabre1's, but I'll take a Sabre2 anyday under equal considerations.
I'd also like to point out that the Sabre2 is a more advanced canopy than a Sabre1 in it's handling. I'd even venture to say that it is tuned to be the highest performance in its class (comparable canopies being Safire2 and Pilot, amongst others).
Turns are faster on the Sabre2 over the original Sabre, and the recovery arc is also different. Lightly loaded (<1.1) I don't know, but moderately loaded (1.3, 1.4 say) the Sabre2 is really quite an aggressive canopy.
BASE #1182
Muff #3573
PFI #52; UK WSI #13
BASE #1182
Muff #3573
PFI #52; UK WSI #13
A Note on Comparing Canopies: When comparing two different canopy designs, such as the original Sabre and the Sabre2, an accurate comparison can only be made if the canopies are the same size, they are flown under similar conditions, and they are flown by the same jumper, or by two jumpers of very similar size and weight. Comparing a 150 Sabre2 to a 170 square foot canopy, for example, would not yield an accurate comparison.
Comparing a Sabre1 150 against a Sabre2 135 is apples and oranges.
