tetra316 0 #1 December 17, 2006 I just ordered a new lineset for my katana. The lower brake lines came not only preset but tacked into place as well. So I cannot adjust the brake settings unless I take out the sitching. Is this something new they are doing with all their canopies? The lineset I had installed at the begining of the year did not come like this. Quote Share this post Link to post Share on other sites
Cacophony 0 #2 December 17, 2006 For years they have been doing this on their Velocities. I believe they do it to stop people from incorrectly adjusting the lines on their high performance canopies. Its a safety factor. Unfortunately it doesn't fit with everyone's respected sizes and adjustments are sometimes required. However, PD is exempt from incorrect adjustments at that point because they already adjusted their high performance parachute and an incorrect adjustment in the field does not link them to addicents or cause them (in theory). Quote Share this post Link to post Share on other sites
everymansaved 0 #3 December 17, 2006 "In theory, communism works, in theory" Homer SimpsonGod made firefighters so paramedics would have heroes...and someone can put out the trailer fires. Quote Share this post Link to post Share on other sites
Samurai136 0 #4 December 17, 2006 Do you need to adjust the brake settings? Have you jumped the new line set? I like to put at least 20 jumps on a new line set (break them in) before deciding the factory setting needs adjustment."Buttons aren't toys." - Trillian Ken Quote Share this post Link to post Share on other sites
tetra316 0 #5 December 18, 2006 QuoteDo you need to adjust the brake settings? Have you jumped the new line set? Haven't had a chance to jump it yet. I've lengthened the brake lines on just about every canopy I've jumped so that's why I was curious about this but we'll see. I haven't had hma before either so maybe my lenthening the lines was because they were just shrinking Quote Share this post Link to post Share on other sites
headoverheels 333 #6 December 19, 2006 QuoteQuoteDo you need to adjust the brake settings? Have you jumped the new line set? Haven't had a chance to jump it yet. I've lengthened the brake lines on just about every canopy I've jumped so that's why I was curious about this but we'll see. I haven't had hma before either so maybe my lenthening the lines was because they were just shrinking My Katana should be on the way with new HMA 650, and I'm sure that I will be unstitching or replacing the lower control lines, if they tacked them down. The marked position on the original set (not HMA) did not leave enough slack for front riser turns, and the Katana really bucked if the tail was also pulled down. Were the lines you got round or oval? Quote Share this post Link to post Share on other sites
tdog 0 #7 December 20, 2006 Quote My Katana should be on the way with new HMA 650, and I'm sure that I will be unstitching or replacing the lower control lines, if they tacked them down. The marked position on the original set (not HMA) did not leave enough slack for front riser turns, and the Katana really bucked if the tail was also pulled down. Were the lines you got round or oval? Mine = Oval HMA (has two flatter sides if that is what you mean) - and the length has been perfect from the factory - I never have had problems with front risers, yet the toggles start to "work" high enough that no range is lost with extra slack... Quote Share this post Link to post Share on other sites
