relyon 0
QuoteThere was a time, where sport canopies were equal. ...
... They are not designed for having several hundreds of jumps.
This appears to be in contradiction.
To my knowledge, the design (7 cell), airfoil, planform, material (F111), lines, and even trim for the PD reserve canopy series was identical to the PD main canopy series while the main series was still being manufactured. PD mains were used for hundreds of jumps, and while the reserves were/are used decidedly less, it's not that they couldn't be because of a basic design limitation.
I know plenty of CRWdogs who have 30-40 reserve rides on the same reserve who notice no difference whatsoever in flight characteristics or flare from the first jump to the most recent.
Bob
At wingloadings under 1 pound per square foot which few experienced skydivers do these days.
30-40 is a lot less than "hundreds" and the wing loadings there are usually still moderate (1.3-1.4) by contemporary standards.
relyon 0
My point was that the statement that F111 7 cell reserves were "not designed for having several hundreds of jumps" is misleading. There is nothing about the basic canopy design (airfoil, planform, lines, material, etc.) that cannot accomodate that many jumps. I gave the PD main/PD reserve canopies as an example; there are others. Whether one wants to jump that kind of canopy that much is very different than whether or not it can be.
How a canopy is wingloaded in practice is an entirely different issue from what the canopy as a whole was designed for. All the F111 mains (and the reserves mentioned) beyond student status I'm aware of were loaded above 1.0 but below 1.5. All flew and landed just fine - repeatably.
As has been the topic of numerous posts, this could be a problem. While admittedly, reserve wingloadings less than 1.0 may be unnecessarily low, they can easily get too high as well. Trade a 79 sq ft 9 cell ZP pocket rocket loaded at 2.0 for a 99 sq ft 7 cell F111 reserve loaded at 1.6? A broken femur (or worse) following a "sucessful" save is embarassing ... at best. I'll pass.
Bob
QuoteAt wingloadings under 1 pound per square foot which few experienced skydivers do these days.
Bob
That will give you a pretty good idea of how reserves glide, turn, flare, etc.
Also, ask your local rigger if you can look at an unpacked reserve.
