GaryRay 0 #1 August 31, 2007 sounds dumb, but i havnt bought a container yet so im just asking it. does the container come with the D-Bag or does the Parachute come with the D-bag...JewBag. www.jewbag.wordpress.com Quote Share this post Link to post Share on other sites
atsaubrey 0 #3 August 31, 2007 there are no stupid questions! Ask away, better safe than sorry."GOT LEAD?" Quote Share this post Link to post Share on other sites
GaryRay 0 #4 August 31, 2007 thank you, clears things up for me :)JewBag. www.jewbag.wordpress.com Quote Share this post Link to post Share on other sites
jakee 1,557 #5 August 31, 2007 The parachute comes with nothing, the container comes with everything.Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
darkwing 5 #6 August 31, 2007 the parachute come with connector links. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
NewGuy2005 53 #7 August 31, 2007 That was not a stupid question at all. Quote Share this post Link to post Share on other sites
councilman24 37 #8 August 31, 2007 All true, but... Often when buying used components somebody has left the d bag, risers and pilot chute on the main. If buying a used container only double check with the seller what comes with it. To replace the risers, d bag and PC can be $200 - $400.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
riggerrob 643 #9 August 31, 2007 Thirty years ago, that was a very confusing subject. Then in the early 1980s, canopy manufacturers ganged up against container manufacturers and wrote Parachute Industry Association Technical Standard 102, which specified which components were supposed to be supplied by which manufacturer. TS102 says that canopy manufacturers are responsible for supplying little more than canopy, lines, slider and connector links. All other components (pilot chutes, bridles, deployment bags, risers, closing loops, etc.) are the responsibility of the container manufacturer. In practice, high-wear items (i.e. main risers) are often sold with main canopies. Since main risers wear out faster than harnesses, it is prudent to replace them every 600 to 1200 jumps, so just try to talk the (harness) seller into reducing his asking price. Quote Share this post Link to post Share on other sites
GaryRay 0 #10 August 31, 2007 wow, there was a lot more to it than i thought, thanks for the insite, if there is anything more anyone has to add please do, im very interested in the topicJewBag. www.jewbag.wordpress.com Quote Share this post Link to post Share on other sites
vid666 0 #11 August 31, 2007 Quotewow, there was a lot more to it than i thought, thanks for the insite, if there is anything more anyone has to add please do, im very interested in the topic ok, more for thought even if you get the risers with the canopy - you may have large 3 rings on the risers, and small on the container that you are using - so those risers will be useless to you. Same thing with the dbag/pc - your container may be setup for a pullout - and you most likely will have a throw out PC - again, would be fairly useless :) Quote Share this post Link to post Share on other sites
