Megatron
Downsizing: 190 to 170
I'm looking to downsize from a 190 to a 170 main. Planning to rent a 170 rig this weekend and give it a go. Will this feel like a big change?
Im currently ~205lb, the 190 loads at about 1.1 for me while the 170 would be roughly 1.3. As a student I started on a 280, then a 240, and finally the 190 which Ive been jumping for some time now. Never has downsizing come with much of a learning curve for me. As a matter of fact the improved handling and increase flare has resulted in more precise flying of the canopy and consistent stand-up landings on the 190. Please note that while the 190 is an F111 canopy, the 170 will most likely be a ZP.
I just sent back my Saber 2 170 demo that I got from PD. I have been flying the 190 for about 250 jumps with an exit weight of around 210 and don't have any problems with it at all.
My first jump on the 170 was a no wind landing. I was moving so much faster that I am used to that I braced for a PLF and preformed a pretty impressive ass over tea-kettle maneuver if i do say so myself.
It was snappier in the air and faster on the landing. It was fast enough to make me think about my flaring technique.
If you have your own rig I would recommend calling the manufacturer of your choice and getting a demo. It was very helpful.
Have Rig will travel ...
The recommendations I've seen (I think it was Brian Germain) strongly recommend changing only one of three variables at one time:
Material
Size
Planform
You're looking at changing at least two, material and size. I don't know if the planform of the 170 is the same as your currrent 190, but I suspect it probably isn't.
You may be better served by trying out a ZP 190 for several jumps to see what the difference in material will do. Reading/accomplishing billvon's downsizing checklist is strongly recommended, as well.
Mike
I love you, Shannon and Jim.
POPS 9708 , SCR 14706
Material
Size
Planform
Nice work! Is this coming from your homework or experience?
Dude, the 190 is a Silhouette, which is a hybrid with a ZP top skin, no an F111 canopy. The 170 is a Sabre2. You'll notice a difference, but its not going to be a hugely drastic earth shattering experience.
Take some extra time to plan out your pattern and fly safe. You know what to do, enjoy yourself after you've opened, did a couple of practice flares and a flat turn or two.
Material
Size
Planform
Homework - note the first sentence. ;)
Mike
Homework - note the first sentence. Wink
Is that more practical than quantum physics? ;)
I think that taking the advice of a canopy designer and a multi-discipline instructor and S&TA with a combined experience of some 35 years in sport and combined total of 15k+ jumps as prudent, yes.
Perhaps you can show us what parachutes you have designed, or canopy piloting books you have written. Maybe a mention of your published safety articles?
Next question?
Mike
I fly a Triathalon 190. I've borrowed a 170 Sabre2 a few times. The difference isn't huge but it is there. As long as you pick a good day (medium,steady winds; low traffic in the pattern:big open landing area), practice flare up high, play with it a bit to get a feel for it, and don't do anything radical, I would think you'll be ok.
Standard disclaimer: not an instructor, ask your instructor ect, ect.
"There are NO situations which do not call for a French Maid outfit." Lucky McSwervy
Well, if you're going to quote Brian Germain, why not also cite his wingloading recommendations, too?
http://www.bigairsportz.com/pdf/bas-sizingchart.pdf
To Megatron - before you decide to downsize you may want to take a look at this chart. (Of course, if you have Mad Skillz of any sort this chart doesn't apply to you :D:S).
"There is only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences." -P.J. O'Rourke
Next question?
I just jumped quite a lot of different canopies between size 300+ and 105, 7,9 cell, airfoil, round, triangular, ZP, hybrid, F111, square, semi and full-ellictical from WL 0.7 - 2.2....and I don't have to quote anyone. I usually not f*cking with others mind and fears.....
Back to the topic. The short practical answer is :"Yes, Go ahead and enjoy"
I see - so you DON'T have anywhere near the experience of the people whose advice I passed on, then.
No, just trying to slam others with less experience than you when their advice doesn't match yours.
Mike
Yes. Things really "start to happen" above loadings of 1 psf. At a loading of 1.3, an uneven flare will dump you to one side or the other. If this happens do NOT "reach out to break your fall." You will turn the canopy even harder and land on your wrist, which is one of the weaker joints.
Also, at those loadings, you will not be able to just "flare all the way" as you come in to land. You'll have to flare gradually, timing the flare so that you get to zero downward speed at zero feet just as the canopy is about to stall. Above 1 psf you can no longer just pull both toggles down at X feet and hope for the best.
This statement worries me a bit. If you jump a new canopy and don't think you have much to learn on it, it's likely that you're not doing anything but turning it gently and landing it straight into the wind. While that is a good idea when you first get a new canopy, by the time you are ready to try _another_ new canopy you should be able to fly the snot out of the larger canopy, including things like turning during the flare, flat turning on final, landing downwind etc.
If you've already done all those things, no worries. For most people there's a bit of a learning curve though.
Why do you think I don't know those sources?
Why do you think I have not any canopy courses?
I'm sorry, I have first hand experience and I'm not a librarian...
Although you have not pointed out that he is overloading that F111 190.....
So jumping that ZP 170 is lot better than a 190 over WL 1.0...
Let me rephrase that a bit..not that there was no learning curve at all, my canopy flying skills have definitely improved as I downsized. What I meant to say what that I never had any trouble landing safely after a downsize..if anything my ability to control the canopy to a smooth landing has improved with higher wing loadings. That trend definitly has a limit to it however, especially at my skill level. Im just hoping its not at the 170 mark.
I'm about 225 with gear btw
I am one of the instructors at his DZ.;)
He should be fine and has been progressing well. He wouldn't be allowed to jump the canopy if the S&TA didn't think that it was right.
Not advice, but an anecdote from my (limited) experience:
I'm about 200 lbs without gear right now, so my exit weight is about 225.
During my A license progression my instructors downsized me from a Navigator 280, to a Nav260, 240, 220, and then 200. Then they downsized me to a Spectre 190. Through the progression, I didn't notice much of a difference from 280 to 240. The 220 seemed noticeably faster than the 240+, and the 200 was noticeably faster than the 220. The 200 also seemed to land better/easier than the 220, which seemed better/easier to land than the 240+.
The Spectre 190 didn't seem much different from the Nav 200. I don't really know why. Maybe it was a fluke, or maybe I just didn't know how to notice.
They (my instructors and S&TA) suggested the first rig I buy have a 190 main, and that I'd probably stick with it for quite a while.
Anyways, at this point I changed dropzones (major geographic shift), and started jumping a Silhouette 190. It was fun, not really any different from what I was used to jumping. Easy to fly, easy to land. I jumped a Sil210 a couple of times, and it seemed be about the same. I jumped a Fusion 190 and a Sabre 170, and they seemed pretty similar, too.
I ended up buying a Sabre2 190, and it's *much* more snappy/reactive than the Silhouette 190. There's about 800 times more power in the flare, It planes out more/longer at the start of the flare, and you have to more gently bleed off airspeed prior to landing in the second stage of the flare. I have no idea what jumping a Sabre2 170 would be like, but I know just going from Silhouette to Sabre2 at the same size drastically changed the flight characteristics I was experiencing.
Just saying, if you're going from a Silhouette 190 to a Sabre2 170, you'll probably notice a difference. If your instructors and S&TA are suggesting it, trust them over the internet, since they have seen you fly and land, and we have not. Me personally, I'm glad I didn't drop in size, too, since just the planeform change was noticeable.
Brian
Jumping a ZP 170 will give you more support than a F111 190 but will be way faster. For the first jumps on a ZP
170 choose your conditions:
1) check with an instructor and get a briefing for approach and flare
2) jump it with a medium to good wind to slow down your ground speed when approaching against the wind.
3) do your approach with plenty of room before you and start your flare at about 15-20 feet but depress your toggles progressively and adjust according what you see at 45 degrees before you where you will land. If ground is coming faster than expected depress your toogles faster. You should be full brakes just before touching the ground (6-12") not before. At all time be very symetrical with toggles when you do your approach. Easy to say but a lot of people have an arm stronger than the other and they start turning at landing. A trick I give is to repeat to yourself at loud voice several times to be symetrical when you do your approach. Don't worry, nobody will hear you. Don't give up flying your canopy even after to touch the ground.
Note: A faster canopy will give you a more powerful flare. But please plan your descent and approach.
Learn from others mistakes, you will never live long enough to make them all.
Hey whats up Dave! I figured someone from Aggieland would recognize me as Megatron haha ..yeah man, I knew that Silhouette wasnt ZP so I guessed F111 by default..didnt know about hybrid. Let me know next time you do another canopy course, Id love to take it!
voilsb, you and I seem to have had the exact same experience downsizing. Thanks for the info.
I figured a 1.3 wl would really start to get into the thick of active canopy flight. Should be fun!
