gauleyguide
Slider size?
I am wanting to replace my slider, the grommets are dinged up pretty good.
Now, If the slider(the new one) were the same size, then it shouldnt matter what it came off of or where it came from should it?
The canopy is a Raven III loaded at point eight. I dont think it would matter if it were a bit bigger, would it?
Thanks
Alan
"Don't keep your pilot chute a secret"
I've done it and it worked OK. It's not recommended, since things other than size (i.e. grommet weight, kill line type, porosity, grommet size) can affect openings and after-opening behavior.
There is not much you can do to change the openings of a Raven III with the exception of leaving the slider off.:)
Sparky
