Cinders 0 #1 January 28, 2009 I really don't know anything about "what fits" in different containers. I don't want to press a safety concern by jamming too big a chute in a container or a too small one (can this cause problems?). Is there a rule of thumb or chart or is it just personal experience? I'm trying to get a container where I could downsize eventually. I can relax in a 210 main and a 190 is no problem, but I give it my full attention. So basically, if I ever move to a 170, what are my options? 190 sized container? Would 210 still be do-able? Quote Share this post Link to post Share on other sites
AggieDave 6 #2 January 28, 2009 Is this a container that you own or are buying used? If so get the serial number and call up Sunrise Rigging. They'll tell you what will fit in that container. If you're buying a new container, call them and tell them what you're wanting to do. They'll tell you if its possible or not. You could even e-mail them.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
AllisonH 0 #3 January 28, 2009 Their containers tend to hold a decent range of canopies. They told me that mine would hold a 135-170. Edit to add: it's a W12-1 (I've put everything from 117-170 in it. The 170 was really tight, 135-150 fit very well, and 117 was pushing it a bit on the small side.) If you're buying used do as suggested above and call/e-mail them with the serial number. If you're buying new, tell them what size you want to put into it (don't lie on the order form) and that you'll want to downsize eventually. They can then build you an appropriately sized container, and when it's finished they can tell you how much you should be able to downsize in it. Or if you called/e-mailed and asked if they made a container that would hold 170-210, I'm sure they could answer that question as well. Quote Share this post Link to post Share on other sites
wildfan75 1 #4 January 29, 2009 Here's their sizing chart: W1 main- sub 100 reserve-106 W2 main- 107-120 reserve-106 W3 main- 120-135 reserve-106 W4 main-sub 100 reserve-113-126 W5 main-120-135 reserve-113-126 W6 main- 135-150 reserve 113-126 W8 main-135-150 reserve 143 W9 main- 150-170 reserve 143 W10 main-150 reserve-160 W11 main-170 reserve-160 W12-1 main 150 loose 170 reserve-160 W12-2 main 170 loose 190 reserve 160 W12-3 main 190loose 210 reserve-160 W13 main 170 reserve 176 W14 main 190 reserve 176 W21 main 190 reserve 193 W22 main 210 reserve 193 W24 main 210 reserve 218 W25main 230 reserve 218 W26 main 240-260 reserve 218 I have a W8. There is no way that I would get a 170 in there, a 150 is tight, a 135 will be perfect and I can imagine that I'll be able to do a 120 if I ever go that low. Quote Share this post Link to post Share on other sites
micduran 0 #5 January 29, 2009 I have a W5 with a Spectre 135 and PDR 126. It is a VERY tight fit.Be patient with the faults of others; they have to be patient with yours. Quote Share this post Link to post Share on other sites
AggieDave 6 #6 January 29, 2009 Is that their new sizing chart or their old sizing chart? The sizing chart changed about 4-5 years ago. An example of the difference is that my W-13 is from 2002 and was sized for a PDr-176 but a 150-170 main. It fit a 170, but it was TIGHT. It fit a 150 perfectly. Also, it fits my Velo 111 quite well. Actually, really well. That's right, I've had the same rig since 2002 and have downsized through a 170 to a X-braced 111 with the rig. --"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
wildfan75 1 #7 January 29, 2009 Must be their new as Scarlett just emailed it to me on 1/19/09 at my request. Editted: Now I'm confused. The chart shows that your rig was sized for a 176 reserve and a 170 main. Which you had in there originally. How has the chart changed when its the same??? Quote Share this post Link to post Share on other sites
degeneration 5 #8 January 29, 2009 I very recently had a Wings rig made with a Pilot 150 main and Smart 150 reserve. The info on te container says I've got a W11... According to that chart my container is made for a 170 main and a 160 reserve. That is not exactly what I ordered it for! Now is this right as there isn't a 150/150 option? Surely given the other options I should have got a W8, 9 or 10? Or is this because of something like the Pilot packs bigger than other canopies, so a 150 Pilot is equivalent to the 170 sized main that they used for this chart? Was very happy with my rig, but now thinking that the years of downsizing may not actually be possible...Sky Switches - Affordable stills camera tongue switches and conversion adaptors, supporting various brands of camera (Canon, Sony, Nikon, Panasonic). Quote Share this post Link to post Share on other sites
JanuszPS 0 #9 January 29, 2009 When I was considering Wings (2 years ago) W8 for 150/150 was an option and still is (specially taking into account that PDR 143 is about 150/151 real area as per http://www.dropzone.com/files/archive/gear/Canopy_vols.html) So that's you option than. Janusz Edit: But the best option is also ask some riggers who have experience with such a combination (W8, 150ZP, 150 Smart).Back to Poland... back home. Quote Share this post Link to post Share on other sites
xenaswampjumper 0 #10 January 30, 2009 QuoteOr is this because of something like the Pilot packs bigger than other canopies, so a 150 Pilot is equivalent to the 170 sized main that they used for this chart? That would be correct. ALL canopies vary in size, even sometimes the exact same type and size of canopy from the same manufacturer. I have a pilot 168 and my container fits a sabre 190. My pilot fits in there nicely. It can make it difficult to size containers and a 150 sabre may fit in one container perfectly and another 150 sabre may be tight in the exact same container. Unfortunately this chart isn't a set rule and it doesn't always work but that is the general rule of thumb. Pack volumes can and do vary. Peoples preferences can and do vary. Some like tight pack jobs and containers, some prefer a looser pack jobs and care less about the "look" of the container. Unfortunately we don't know that unless it is specified on the order form but when specified we do our best to accommodate the request, otherwise we do what seems to work in most cases. We welcome any feedback, especially from riggers, about canopy sizing as that is the best way to get good info, especially with all the newer canopies and European manufacturers out there that we have little or no experience packing. Scarlett till later have fun & love each other seeya mb65johnny gates.... In skydiving, the only thing that stops you is the ground.............. PMS# 472 Muff #3863 TPM#95 Quote Share this post Link to post Share on other sites
Gary73 10 #11 January 31, 2009 Always order the next size up from what the Wings sizing chart says. Ditto with Mirage. "Extraordinary claims require extraordinary evidence." - Carl Sagan Quote Share this post Link to post Share on other sites
Lsebek1 0 #12 March 14, 2014 I just checked the chart on their website and here is what it says: *** Please note disclaimer and additional info at bottom!*** Container Size Dimensions (L x W x H) Reserve Canopy F-111 w/ Microline Main Canopy ZP w/ Microline W-1 14 x 10 x 5 PD 106R, Raven-M 109, Techno 96 up to 100 W-2 15 x 10 x 5 PD 106R, Raven-M 109, Techno 96 up to 120 W-3 16 x 10 x 5 PD 106R, Raven-M 109, Techno 96 up to 135 W-4 15 x 10 x 5 PD 113R, Raven-M 120, Tempo 120, PD 126R (tight) 95 - 107 W-5 16 x 10 x 5 PD 113R, Raven-M 120, Tempo 120, PD 126R (tight) 95 - 120 W-6 17 x10 x 5 PD 113R, Raven-M 120, Tempo 120, PD 126R (tight) 120 - 135 W-7 15 x 11 x 5 PD 126R, Raven-M 135, Tempo 150 (tight) 107 - 120 W-8 16 x 11 x 5 PD 126R, Raven-M 135, Tempo 150 (tight) 120 - 135 W-9 17 x 11 x 5 PD 126R, Raven-M 135, Tempo 150 (tight) 135 - 150 W-10-1 16 x 11 x 5 PD 143R, Raven-M 150, Tempo 150, PD 160R (tight), Tempo 170 (tight) 107 - 120 W-10 17 x 11 x 5 PD 143R, Raven-M 150, Tempo 150, PD 160R (tight), Tempo 170 (tight) 135 - 150 W-11 18 x 11 x 5 PD 143R, Raven-M 150, Tempo 150, PD 160R (tight), Tempo 170 (tight) 150-170 W-13-1 16 x 11 x 6 PD 160R, Tempo 170, Raven-M 181, PD 176R (tight) 150 W-13 17 x 11 x 6 PD 160R, Tempo 170, Raven-M 181, PD 176R (tight) 170 W-14 18 x 11 x 6 PD 160R, Tempo 170, Raven-M 181, PD 176R (tight) 190 W-18 17 x 13 x 5 PD 176R, Raven-M 181, Raven-M 218 (tight), PD 193R (tight), Tempo 210 (tight) 170-190 W-19 18 x 13 x 5 PD 176R, Raven-M 181, Raven-M 218 (tight), PD 193R (tight), Tempo 210 (tight) 190-220 W-20 19 x 13 x 5 PD 176R, Raven-M 181, Raven-M 218 (tight), PD 193R (tight), Tempo 210 (tight) 220-240 W-21 18 x 13 x 5 PD 193R, Raven-M 218, Tempo 210, PD 218R (tight) 170-190 W-22 19 x 13 x 5 PD 193R, Raven-M 218, Tempo 210, PD 218R (tight) 190-220 W-23 20 x 13 x 5 PD 193R, Raven-M 218, Tempo 210, PD 218R (tight) 220-240 W-24 17 x 13 x 6 PD 218R, Raven-M 249, Fury 220 200-230 W-25 18 x 13 x 6 PD 218R, Raven-M 249, Fury 220 240-260 W-26 19 x 13 x 6 PD 218R, Raven-M 249, Fury 220 280 W-27 17 x 13 x 7 PD 235R, Raven-M 282, Tempo 250 240-260 W-28 18 x 13 x 7 PD 235R, Raven-M 282, Tempo 250 260-290 W-29 19 x 13 x 7 PD 235R, Raven-M 282, Tempo 250 290-310 W-30 18 x 13 x 7 PD 253R, Raven-M 282, PD 281R (tight) 240-260 W-31 19 x 13 x 7 PD 253R, Raven-M 282, PD 281R (tight) 260-290 W-32 20 x 13 x 7 PD 253R, Raven-M 282, PD 281R (tight) 290-310 ***The above chart assumes main canopies with standard configuration (ie,no no cross-bracing).When ordering your custom Wings please indicate on the order form exactly which main and reserve canopies you intend to use in your new Wings so that we may build you the most suitable container. We are able to accommodate many different combinations of canopies and can create new patterns when necessary. If your main and/or reserve has Dacron lines, be sure to indicate that as well since it does affect pack volume. If you have any questions, please don't hesitate to contact us! ***Whatever doesn't kill you makes you stronger! L.S. Quote Share this post Link to post Share on other sites
