Milo 0 #1 April 24, 2009 I read this in another thread. What is this? Is it the standard pilot chute that then pulls your closing pin or something else that also pulls your closing pin? Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #2 April 24, 2009 It is a deployment system where the pilot chute is stored inside the main container with the rest of the assembly. Part way down the bridal is a grommet; through that grommet slides another piece of bridal material. On one end of that piece is the closing pin, on the other is a handle. The handle is stored in a keeper on the bottom of the rig, right where the throw out handle is on a throw out rig. When you pull the handle the pin is pulled. Once the container is opened you continue pulling until the pilot chute is in the air stream. Quote Share this post Link to post Share on other sites
riggerrob 643 #3 April 24, 2009 Yeah! Whatever Andrew said. Remember that - back in the 1970s - skydivers were experimenting with a variety of hand-deploy pilot chutes to replace main ripcords. Two systems emerged. Throw-out now makes up 90 percent of today's market. Pull-out is only about 5 percent of toady's market. Try to think of pull-out as a small, soft ripcord. Pull-out fanatics got handle location (lower right corner of container) correct very early in the process and it only took thrower-outers another 15 or 20 years to convert to the true religion ... er simplest handle location. Quote Share this post Link to post Share on other sites
JerryBaumchen 1,441 #4 April 24, 2009 Hi rob, Quote Pull-out fanatics got handle location (lower right corner of container) correct very early in the process and it only took thrower-outers another 15 or 20 years to convert to the true religion ... er simplest handle location. That's why us 'pull-out fanatics' believe it to be the best method. I am also a believer that the reserve ripcord should be on the right-hand MLW for right-handed people. I've always built my own personal rigs this way. Many, many years ago I was at a Turkey Boogie in Spaceland and the guy sitting across from me said that he would never jump that rig. I asked why and he said because of the handle(s) location. I just laughed; you cannot convert a true believer, they just love that Kool-Aid. JerryBaumchen Quote Share this post Link to post Share on other sites
MakeItHappen 15 #5 April 26, 2009 QuoteI read this in another thread. What is this? Is it the standard pilot chute that then pulls your closing pin or something else that also pulls your closing pin? See Deployment Initiators .. Make It Happen Parachute History DiveMaker Quote Share this post Link to post Share on other sites
