Absolutely not. Rutan's planes never count for stuff like this. They work only by the magic of voodoo curses.
Actually it makes perfect sense... compare the size of the winglets (which are really vertical tails on the wingtips, not the same as standard winglets) with the size of that nose rudder. The rudder disturbs the aircraft in yaw, but the aircraft still has yaw stability due to the vertical tails mounted well aft of the CG. (ie CG is ahead of the aerodynamic center).
A perfect example of that "ground loop" in the air a standard plane flying backwards. Not usually possible, unless the plane is in a tail slide. What happens to a plane in a tail slide that gets disturbed in yaw? CG is now behind the aerodynamic center. It'll flip right over unless the pilot makes constant fine adjustments to the rudder. Unstable, but controllable to a point. As the "angle of attack" on the tail increases (sideslip angle, beta) of a plane in a tail slide, the yaw moment will increase. This is opposite what will happen when flying forward. Increase beta, yaw moment decreases (increases in the opposite direction, really).
You can post now and register later.
If you have an account, sign in now to post with your account.
Dave
