is to clean and lub your yellow cable
I'm with ya on the 'clean' but would be careful with the lube.
Throw a little graphite on them. They dont harm the material like a petrol based lube would
RMURRAY 1
from the UPT Vector3 manual for every 3 months:
"Clean and lubricate the release cable with a light oil such as “3 in 1” brand or silicon"
yes, the manual also says only a thin layer.
I don't need to lube my red (teflon) cable however I bought a couple of cans of food grade silicon a long time ago and use that to clean it twice a year. My point of this being I bet no more than 10 percent of jumpers follow the rig manufacturers recommendations when it comes to (yellow) cutaway cables maintenance.
riggerrob 643
The major issue is CLEANING cables. Cleaning cables drops cutaway force from 25 pounds to less than 5 pounds. After that, lubrication is a formality.
OTOH too much lubrication can trap desert grit, radically increasing cutaway forces.
Since it is difficult to have two standards for two different climates (Wisconsin pasture versus Southern California desert), we settle for "less lubrication being better."
riggerrob 643
See pictures. They are much easier to use, as likestojump said, hook a thumb in each handle and go right, left. Some people say it is safer if they have a different feel. If you can't tell your right from you left maybe you should not be jumping.
Sparky
Do I detect a hint of sarcasm?
Tee!
Hee!
Seriously, the primary reason fatality rates remained constant - while jump numbers increased dramatically - during the 1980s, was STANDARDIZATION OF HANDLES, the same as motorcycles.
It is all about establishing a standardized FLOW of handles, starting at lower right and working your way diagonally across your body up to your left shoulder. After the Second World War, the United States Air Force recognized that different shaped handles helped pilots pull the correct handles in the correct sequence, reducing "finger problems."
That is why flap controls feel like tiny flaps and undercarriage retraction levers feel like tiny wheels. Differentiating controls by different locations and tactile sensations helps differentiate them in stressful situations, reducing the risk of people pulling handles out of sequence.
ON that note, I would applaud a cloth loop on a cutaway handle, as seen on some tandems.
I located another picture that shows the handle better.
Sparky
Earth-tone 'Bounce & Blend' colors...I like it!
Sangi 0
I've seen something similar on an Atom rig. Both handles seemed to be metal, but covered with textile.
I've got that "textile" reserve handle on my Atom Axis..
www.basik.fr offers really cool hooktable cutaway handles
teason 0
A "D" handle cutaway can therefore address the concerns of hard pulls that can arise from hi-speed spinning mals.
Testing done on reserve ripcord handles years ago showed a 20% or so increase on pull force when hooking a thumb into the handle. That means you can produce more pull force with a "D" handle than a pillow.
Correction - a handle you can hook your thumb through. DOES NOT HAVE TO BE A D OR A METAL HANDLE.
Here's a nice VooDoo version. I think it's cleaner and more user friendly.
Yeah... you've OBVIOUSLY never seen Sparky's choice in jumpsuit colors.
Had to wear friggin' sunglasses if on the plane with him!
He wouldn't have bounced and blended in unless he landed in a truck-load of oranges.
yeah, i like the colors too.
riggerrob 643
That soft loop, cutaway handle looks a lot like some pioneered by Stewart Systems (now SSK the North American overhaul shop for Cypres).
It satisfies the best of both worlds, light and easy to grab with cold hands in bulky gloves.
On a skydiving rig when the shit hits the fan you only have 2 handles. One is on the right and one is one the left. Hook your thumbs in both and pull the right one first. I see no reason for them to be made of different materials. jmo
Sparky
Sarcasm, me?
Sparky
