Hellis 0 #1 March 31, 2010 I tried to change batteries on my Viso but its still showing empty. What am i doing wrong? The manual says: Quote Carefully slide out battery holder and remove batteries. Install new batteries using the correct polarity. Use only CR-2325. After battery replacement or resetting, the battery system requires 2 minutes to calibrate itself before showing the correct status. While calibrating, the battery icon toggles between full and low. Should it be on or off when calibrating itself? Neither seems to work for me. The battery icon has not toggled between anything, its just flashing as if its empty Quote Share this post Link to post Share on other sites
regulator 0 #2 March 31, 2010 I don't have a Viso, but I do have an Optima. I had to change the batteries in it this past weekend and the device was on...I just slipped the battery slot out and replaced the batteries...they were in backwards and nothing on the device lit up, so I just flipped the the opposite way and it started up by itself and showed full battery strength. Hope this helps Quote Share this post Link to post Share on other sites
Hellis 0 #3 March 31, 2010 The batteries are not upside down, i know that. Did you turn of the device before pulling out the old batteries? Quote Share this post Link to post Share on other sites
regulator 0 #4 March 31, 2010 No...the Optima was still on. I just pulled the batteries and the display slowly faded. I put them in the first time...nothing on the display. Then I flipped them over and it came right up. Quote Share this post Link to post Share on other sites
Hellis 0 #5 March 31, 2010 I tried starting the Viso, opend the batterytray for a while (untill screen got blank and some more) the pushed it back in. Still empty batteries?And i cant see it calibrating itself Quote Share this post Link to post Share on other sites
buff 0 #6 March 31, 2010 I have a Viso and replaced my batteries last night. Unit was off, pulled out the battery tray and inserted two new CR2325 batteries and it powered up right away with everything stored in it as before. There is only two ways I see that could not be correct. Both batteries together but inserted in the tray incorrectly or batteries stacked together incorrectly. Possibly you have two bad batteries or incorrect type of battery.It's called the Hillbilly Hop N Pop dude. If you're gonna be stupid, you better be tough. That's fucked up. Watermelons do not grow on trees! ~Skymama Quote Share this post Link to post Share on other sites
karma 3 #7 March 31, 2010 Have you tried the reset button? Quote Share this post Link to post Share on other sites
Hellis 0 #8 March 31, 2010 Both are CR2325, just opend again and had a look. Both was facing the correct way. Now that i put them back in the icon shows one bar (50%?). But now i looked at the packaging to the batteries, they seem to have a "datestamp". It says: PD/EP (MMYY) 0309/0316 PD/EP (MMYY) 0704/0711 on them. Im guessing PD is production date, but whats EP? Im guessing one of the batteries is older, could that be the problem? Quote Share this post Link to post Share on other sites
Hellis 0 #9 March 31, 2010 No, wont that erase the log? Edit: I just had a look in the manual, it says: Quote Press a paperclip into the tiny hole on the side of the unit and release. The unit restarts. After battery replacement or resetting, the battery system requires 2 minutes to calibrate itself before displaying the correct status. While calibrating, the battery icon toggles between full and low. Resetting the VISO Note: Reset the unit after battery replacement, when troubleshooting and when verifying software version number. Why dont they say that on the battery replacement page? Quote Share this post Link to post Share on other sites
shropshire 0 #10 March 31, 2010 Does sound like you have a bad battery or connector, Are the terminals clean? Does this device have a small spring (part of the circuit - a daft idea too)? (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
Hellis 0 #11 March 31, 2010 The batteries are clean, but i dont know about the connectors. I have no clue if it has a spring or not. I did remove the batteries again, started it, and tried to reset it. No change yet ~3 min after reset Quote Share this post Link to post Share on other sites
JohnnyMarko 1 #12 March 31, 2010 If you have an original Viso and send it back to L&B they'll probably send you a Viso II with no questions asked...I love my Viso II. Oh and sorry, no advice on the batteries Quote Share this post Link to post Share on other sites
shropshire 0 #13 March 31, 2010 The L&B ones have a spring ... see picture (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
Hellis 0 #14 March 31, 2010 I dont need a Viso II, besides who got time to replace a altimeter just as the season is about to start??? But lesson learnd: always bring the viso along to the store when i need to replace the batteries. Those fuckers are way to expensive to only get 50% Quote Share this post Link to post Share on other sites
JohnnyMarko 1 #15 March 31, 2010 Quote besides who got time to replace a altimeter just as the season is about to start??? good point...good luck fixing it Quote Share this post Link to post Share on other sites
Hellis 0 #16 March 31, 2010 Quote The L&B ones have a spring ... see picture I dont think thats a Viso. It looks like the backside of a Protrack Quote Share this post Link to post Share on other sites
regulator 0 #17 March 31, 2010 When I looked at the L&B website it looked (on the backside) very similar to my optima http://www.l-and-b.dk/viso.html Quote Share this post Link to post Share on other sites
mstlaurent 0 #18 April 2, 2011 Quote Now that i put them back in the icon shows one bar (50%?). But now i looked at the packaging to the batteries, they seem to have a "datestamp". It says: PD/EP (MMYY) 0309/0316 PD/EP (MMYY) 0704/0711 on them. Im guessing PD is production date, but whats EP? Im guessing one of the batteries is older, could that be the problem? I got the same problem. Those batteries seem to discharge before their expiry date (EP = Expiry Date). I will check the PD/ED next time. I know this thread is old but it may still help. :-) Quote Share this post Link to post Share on other sites
Hellis 0 #19 April 3, 2011 Quote Quote Now that i put them back in the icon shows one bar (50%?). But now i looked at the packaging to the batteries, they seem to have a "datestamp". It says: PD/EP (MMYY) 0309/0316 PD/EP (MMYY) 0704/0711 on them. Im guessing PD is production date, but whats EP? Im guessing one of the batteries is older, could that be the problem? I got the same problem. Those batteries seem to discharge before their expiry date (EP = Expiry Date). I will check the PD/ED next time. I know this thread is old but it may still help. :-) Ha! This is a oldie. I would also guess ED would be expiry date, but they ssaid EP. Anyways a few weeks after this thread died the batteryindicator showed 100% Quote Share this post Link to post Share on other sites
