bodypilot90
Checklist - Engine restart in the air
Yeah, I've seen this same guy in a couple of other photos doing the same thing in a couple of other types of planes. What a nut! :S
To put your life in danger from time to time ... breeds a saneness in dealing with day-to-day trivialities.
--Nevil Shute, Slide Rule
I think he was a stunt man Paige. It would take too much force to hand-prop a plane, he'd never be able to do it like that, couldn't get enough leverage to pull against the compression of the engine.
Not true, you have to hand prop J3's...I have done it several times.
I have even hand proped a Cessna 152 when it's battery died.
I have heard stories about using a rope and a truck to start a DC-3 here in Zhills back in the day.
BTW the position he is in is the way to hand prop a J3 when you are by yourself.
That's not the only place it's been done. ;):P:$
ltdiver
I've seen that done as well - the starter went out on the engine, and the pilot aske if anyone had a pickup with a tow attachment on the back. It was fun to watch, and it worked.
you can burn the land and boil the sea, but you can't take the sky from me....
I WILL fly again.....
I've also hand-proped several different planes, Aeronca Champ, J-3, Cessna 172 to mention a few. yes, the Cub and the Champ required it because they didn't have electrical systems. The point that I was making was that he, being up in the air, not with feet on solid ground would not have enough leverage to pull the prop through for hand-prop start of engine.
Also it would be completely unnecessary. It the aircraft was dived the airflow would cause the prop to windmill (unless the engine was seized) and the pilot could restart from there, all being well enginewise.
That photo reminds me of an old-time aviation story I read about a year ago. Engines weren't very reliable, and were high maintenance. A couple of guys wanted to set a flight endurance record. In order to stay in the air long enough, they had to crawl outside the plane to add engine oil and change spark plugs - while in flight. Supplies and food were lowered to them on a rope, from another airplane.
I am surprised that no one has realized that this is a photoshop pic... look closer
hrmphh, maybe im seeing things..but i think he is right.
the shadow on the tail and the shadow on the nose created by the person dont look like they match up. sun in two different posistions.
