wildblue
Cisco people - little help?
So I have this Catalyst 4000 switch that likes to spontaneously reboot:
Re-boot History: Feb 03 2004 13:50:27 0, Jan 06 2004 14: 5:33 0
Nov 04 2003 21:58:14 0, Oct 07 2003 9:31:53 0
Sep 17 2003 11:45:14 0, Jul 08 2003 5: 3:42 0
Jun 13 2003 9:22:49 0, Apr 30 2003 14:22:14 0
Feb 25 2003 13:56:42 0, Jan 22 2003 9: 0:33 0
It's pretty consistent - once a month.
I don't really know much about these things, so I'm asking - what would cause this? I know it hasn't been touched in the 4-5 years we've had it. Would a software update maybe fix the problem?
Version info -
WS-C4003 Software, Version NmpSW: 4.5(1)
Copyright (c) 1995-1999 by Cisco Systems, Inc.
NMP S/W compiled on Mar 29 1999, 15:49:45
GSP S/W compiled on Mar 29 1999, 10:56:40
System Bootstrap Version: 4.4(1)
My only other thoughts were environmental - but it's all cozy in its rack in the server room. Any ideas? Or at least point me in the right direction?
it's like incest - you're substituting convenience for quality
I dunno - full buffers / overflow?
Did you research the Cisco site to find spontaneous reboot issues in that model? I'm thinking some kind of overflow condition that triggers a reset, like any other processor, assuming it's an IOS issue.
Perhaps a 'power bad' condition? Can you monitor the power supply? Temp faults would probably result in a lockup; aside from that, I think the Cisco IOS has a few "end-of-the-world" firmware resets it'll try in order to get itself running again.
There are a couple of Cisco gurus who post here regularly; they'll most likely be along shortly. Sit tight.B|
mh
"The mouse does not know life until it is in the mouth of the cat."
I don't think that's it. The "free mbufs" don't seem to decrease and stay there.
Yes, the only thing I could find only applies to Software Relase 12.1(11b)EW
I'm going to plug it into a different UPS, we'll see if that help. I did notice:
" Power Supply 1 Failures: 1 Power Supply 2 Failures: 64"
... it doesn't have a "Power Supply 2" - so I'm wondering if there's a voltage drop, and it's trying to switch to power supply 2. Or, if it just checks it on a reboot, it's not there so it logs an error. Dunno.
I would guess it has a publicly accessable IP and you are prolly getting hit. Update IOS! 5 years is way to old.
No, I'm certain it's not a DOS or any type of attack like that. I would love to upgrade th IOS, however, to do damn near anything on Cisco's site (including downloading IOS images) you have to be registered and have some kind of service contract with them - which I don't have.
Well, it could be a lot of things. It could indeed be the power supply getting weird; switching power supplies do have a limited lifespan. Those dates are pretty spaced out.. Is it possible that it's been happening for longer than that but you didn't notice? The reboot log only holds a certain number (I think the last 10).
OTOH, I really can't tell you how often this sort of problem gets fixed with a software upgrade. It's pretty often. Personally, I'd try that first. Failing that, if you have maintenance, call TAC. If you don't, you should buy maintenance and THEN call TAC because they'll want to replace it and smartnet is cheaper than buying a new one. ;)
CCIE#2006 "old school router jockey" B|
7CP#1 | BTR#2 | Payaso en fuego Rodriguez
"I want hot chicks in my boobies!"- McBeth
Well, I kinda inherited this problem. It's probably been happening ever since we got the thing, just no one noticed/cared. If you look at those dates, it's happened once a month, sometimes skipping one month, for the last year at least.
I'm going to try the software update as soon as I find someone with access to the CCO site ;)
And we don't have the smartnet coverage on it anymore, but renewing it then reporting the problem has crossed my mind - I'm just going to see if I can save myself $1,400 first.
Start with the simplist things first. I have found out as a tech. if you over look them and try to put too much time in the big stuff. I find it was a quick fix that took me 2 hours to figure out.
Bottomless Beers and Blue Skies!
* Brother_Brian *
D.S.W.F.S.B. #2
You told me you were CCIE - you never told me you had that low of a license #.
I had NO idea I was in the presence of greatness. Hell, I even jumped with his greatness!B|
Most people don't know what you've been through, huh?:P Or, are you one of those naturals!>:(
Katie! you are a geek?? I'm impressed!
you can burn the land and boil the sea, but you can't take the sky from me....
I WILL fly again.....
