The probability is almost zero but not completely at zero.
Just my thoughts . . .
JerryBaumchen
PS) I would hate to be on the committee trying to write a standard for TSO-authorization of an AAD. I suggest not going 'there.'
I have no intention of opening up that "can of worms." As far as the very big "if" a cutter could jam on a loop. JMO, the "if" is big enough that I won't jump a rig with a cutter mounted above the freebag or could lock the through loop, in the case of the Racer.
billvon 3,058
>It is obvious that Argus was outlawed by the APF with a very weak investigation.
Agreed. However, it is not their role to prove that the Argus is safe. It is their role to determine that it MIGHT kill skydivers. They have done so.
It is now in Argus's responsibility to provide a thorough investigation to both determine the cause and ensure it will not happen again.
Take the case of a commercial airliner whose rudder often falls off. It is not the job of the FAA (or other national authority) to determine why the rudder falls off and/or to fix the problem. It is merely to determine that yes, the rudder often falls off, and must be fixed.
Hi medic,
I have thought a lot about this; and I willing admit that it is a big IF.
Any rig in which the cutter is above the pilot chute or above the bag has this potential. As does the Racer & the Reflex.
JerryBaumchen
