Airviking 0 #1 December 9, 2010 I used to flat pack, (which was sooo easy ) now I'm learning Propack/Psychopack. Seems like nobody uses drag mats any more. Instead of pulling the rig (by pulling the lines) toward the bag while stowing the lines, the bag is walked toward toward the rig. Why? Seems like a lot more physical work than just sitting in one spot with the bag, and pulling on the lines.I believe you have my stapler. Quote Share this post Link to post Share on other sites
AggieDave 6 #2 December 9, 2010 Dragging the rig across the floor causes wear and tear on the container fabric. Doesn't sound like much, but if you keep the rig for 10 years and do thousands of jumps, all that little wear can add up.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
Airviking 0 #3 December 9, 2010 But with a drag mat, the only thing actually dragging is the mat and the lines.I believe you have my stapler. Quote Share this post Link to post Share on other sites
AggieDave 6 #4 December 9, 2010 Sure, if you want to use a drag mat. For many, a drag mat is a waste of time (unless packing outside) and it is easier/quicker to just walk the d-bag up the lines. Just like some people use packing weights, some don't. Some use a pull up cord, some use a packing tool. Some pack themselves, some use packing tools...er, packers...It's all a choice. --"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
pchapman 279 #5 December 9, 2010 There seems to be no reason that drag mats had to die out. But I'm guessing that the greater amount of indoor packing helped do them in. No longer is everyone outside, keeping the rig off the grass & dirt, and then putting the mat on top of the rig to keep the sun off. Quote Share this post Link to post Share on other sites
Airviking 0 #6 December 9, 2010 Quote ...some use packing tools...er, packers... Thanks, Just wanted to make sure it isn't not based on some wierd myth about repeatedly pulling on the lines.I believe you have my stapler. Quote Share this post Link to post Share on other sites
millertime24 8 #7 December 9, 2010 I'm with Dave. I only use my packing mat when the area I'm packing is dirty. Also, I walk up the lines and have my packers do the same thing. I dont like the thought of my wingsuit being drug across the floor.Muff #5048 Quote Share this post Link to post Share on other sites
stayhigh 2 #8 December 9, 2010 I feel that when you drag the container upwards, it opens better. I only do that when I pack at my house.Bernie Sanders for President 2016 Quote Share this post Link to post Share on other sites
Airviking 0 #9 December 9, 2010 QuoteNo longer is everyone outside, keeping the rig off the grass & dirt, and then putting the mat on top of the rig to keep the sun off. Yeah, that's one thing I'm gonna miss. Back in "the good old days", skydiving was entirely an outdoor activity. After you landed, you packed outside, which meant that you stayed connected with the sky, the planes taking off and landing, and the skydivers landing. Now, skydiving is mainly indoors. Packing, dirt diving, reviewing videos etc, all done indoors.I believe you have my stapler. Quote Share this post Link to post Share on other sites
AggieDave 6 #10 December 9, 2010 Quote Just wanted to make sure it isn't not based on some wierd myth about repeatedly pulling on the lines. How much do you weigh? How fast are you going when you deploy? Now, how much does the rig weigh? How strong are you when you pull your lines with one hand?--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
kellja2001 0 #11 December 9, 2010 I've been reading about this for a while, and looking at other's equipment, some of whom I know drag, others, I'm pretty sure don't. When I look at similar aged containers, the additional level of wear I've seen is minimal (bear in mind, I've only seen a few hundred rigs, not exactly a large sample), with the worst I've seen being a slight discoloration to the 3-ring ring cover. Now the thing that really worries me is handles. At my DZ there are metal support pillars attached to the floor of the packing hall by four large bolts. Get a reserve handle snagged on one of those and you're going to look like a bit of a tit. Quote Share this post Link to post Share on other sites
Airviking 0 #12 December 9, 2010 Quote Quote Just wanted to make sure it isn't not based on some wierd myth about repeatedly pulling on the lines. How much do you weigh? How fast are you going when you deploy? Now, how much does the rig weigh? How strong are you when you pull your lines with one hand? I kinow, I know, I just grasping at straws with that statement. But what I've gotten is that (assuming a clean packing surface) people prefer to move the bag to either dragging the rig (because of wear), or mounting a drag mat (because of inconvenience).I believe you have my stapler. Quote Share this post Link to post Share on other sites
airtwardo 7 #13 December 9, 2010 I use a drag mat, even indoors...My rig with 500+ jumps on it & looks like new. The mat has a pocket with spare bands, pull-ups and closing loops, never have to hunt mid-packing. I like pulling the rig to me because it's what I've always done, I feel it keeps the lines straight and tight. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
DBCOOPER 5 #14 December 9, 2010 Quote. Back in "the good old days", skydiving was entirely an outdoor activity. After you landed, you packed outside,.... I sort of remember something about going inside and packing on a table....Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
rehmwa 2 #15 December 9, 2010 I drag the rig to me, I like how it helps me keep my lines straight and my stows neater - for me anyway. concerns - overall wear? I don't see much effect in overall gear wear Handles - yup, don't like to think about them getting caught specific wear? - that little square patch that covers the nylon loop for the cutaway system - that wears out faster definitely. I don't like that none of this is making me into a bag-walker yet though ... Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants Quote Share this post Link to post Share on other sites
Airviking 0 #16 December 9, 2010 Quote Quote . Back in "the good old days", skydiving was entirely an outdoor activity. After you landed, you packed outside,.... I sort of remember something about going inside and packing on a table.... That musta been before the good old days.I believe you have my stapler. Quote Share this post Link to post Share on other sites
jonstark 8 #17 December 9, 2010 Walk the bag. Quote Share this post Link to post Share on other sites
councilman24 37 #18 December 10, 2010 But I used my drag mat as the anchor for indoor packing instead of a weight.I put hook velcro on the far end of the mat, along with a pile cover. The hook bit into the carpeting in our indoor packing area. I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
indyz 1 #19 December 10, 2010 I'll go with option #3. I do my locking stows, then carry the bag to the container (without stowing anything else), sit down, and do the rest of the stows. Quote Share this post Link to post Share on other sites
dcfreefly 0 #20 December 10, 2010 I used to be a dragger cause I'm lazy. For some reason I starting walking the bag earlier this year, now it feels weird when I drag it Quote Share this post Link to post Share on other sites
talon2 0 #21 December 10, 2010 Hey Viking, No one has yet extolled the virtue of drag packing rounds.............Always preceded by "scuse me miss, could you stand tension for me?"Great way to meet girls................ Quote Share this post Link to post Share on other sites
mjosparky 4 #22 December 10, 2010 QuoteHey Viking, No one has yet extolled the virtue of drag packing rounds.............Always preceded by "scuse me miss, could you stand tension for me?"Great way to meet girls................ +1 You beat me to it. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
primetime 18 #23 December 10, 2010 I used to be a dragger. Now I walk the bag to the rig. You can keep the lines just as tight, it just takes a few hundred jumps of practice. On rigs that have been dragged across the packing floor for years, I've seen friction damage on the bottom of the risers, right where the smallest ring is attached. Scary! As stated above, not dragging the rig makes even more sense when a wingsuit is attached. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #24 December 10, 2010 Walk the bag. I'd rather use other tools for cleaning. Its really hard to clean a rig. I did try that. Quote Share this post Link to post Share on other sites
Airviking 0 #25 December 10, 2010 Alright, as usual when I ask a question, all the replies average out to "whatever...". (Probably because I tend to ask meaninless questions out of boredom.) That said, I'm gonna split the difference: For my first stow, I will drag the rig on a mat, for the second stow, I will walk the bag, etc. until done. I believe you have my stapler. Quote Share this post Link to post Share on other sites
