sky-pimp 0 #1 November 3, 2007 Self confession I did a jump last week , great skydive good opening until i released my brakes and pumped them to check my lines my right hand toggle came off in my hand, canopy was flying correctly and i had time to get the feel of what input i needed to use my rear risers to land with. Landed OK with a little to much input and just staled a little. Upon inspection of my rig there was no snapped line . what it turned out to be was the brake lines had been finger trapped but not stitched or tied in a Knot to prevent them from coming loose . the right hand line was the same and just pulled apart very easy. that was approx my 20th jump with my brake lines like that . This was a brand new canopy and i was unaware of what i had done. i was lucky and embarrassed as i like to think i am safety conscious lessons learned. YeHaaaaaaaaaaa Quote Share this post Link to post Share on other sites
darkwing 5 #2 November 3, 2007 Glad you didn't die. Who put your main together for you? This is a good lesson in learning your gear. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
sky-pimp 0 #3 November 3, 2007 I put it together , the error is all my own . the reason i confessed my mistake was to make anyone who could be in the same situation to think about it and CHECK ......YeHaaaaaaaaaaa Quote Share this post Link to post Share on other sites
Remster 30 #4 November 3, 2007 Quote I put it together , the error is all my own . the reason i confessed my mistake was to make anyone who could be in the same situation to think about it and CHECK ...... At the very least, ALWAYS knot it... Remster Quote Share this post Link to post Share on other sites
upndownshop 0 #5 November 3, 2007 My X had the same problem, she chose to chop it, which I am glad, she is not the best with canopy control. Her rigger Suzie still denies doing it. Ultimately it is the jumpers responsibility but for a rigger not to accept it was irritating. But all is well now, they are rommates and neither jumps so at least they are safe. So glad it didnt happen on landing for both of you. Quote Share this post Link to post Share on other sites
kenneth21441 0 #6 November 4, 2007 I must comend you for fessing up to your experience. Lesson learned. For reference check the manual that comes with your system as these manuals give alot of great information for someone that is doing this. Then of course I would songly suggest that you do take it to a rigger to look it over to make sure that all is well. But I do like someone that takes the time to try to do it themselves. Just have a double check next time.... to be sure.... Always.// Just my two cents on this area.....Kenneth Potter FAA Senior Parachute Rigger Tactical Delivery Instructor (Jeddah, KSA) FFL Gunsmith Quote Share this post Link to post Share on other sites
ZigZagMarquis 9 #7 November 5, 2007 SP, Good on you for fessing up to your mistake and sharing this informaiton. Et all... this is not the first time I've seen this failure mode during my time in the sport; where an apparently "properly" hooked up toggle really is not. My 2 cents / what I do even with a brand new canopy ... is hang it up and insepct it... look in every cell... look at each and every attach point on the cnaopy... look at each and every casscade and make sure ALL the bar-tacks that should be there are there. Personally, if the brake lines aren't factory set, I tie them in a knot & finger trap the excess rather then just finger trapping them and stitcing them... in case you ever want to retie them for what ever reason. Quote Share this post Link to post Share on other sites
billeisele 130 #8 November 5, 2007 good lesson for all, i saw a main where the fingertraps on the suspension lines were not sewn, the owner jumped it twice, on the second jump i noticed the strange shape, some of them had come apart always check your gearGive one city to the thugs so they can all live together. I vote for Chicago where they have strict gun laws. Quote Share this post Link to post Share on other sites
popsjumper 2 #9 November 6, 2007 Thanks! Good post and a good learning tool for others. Excellent. Brings home the point of good gear checks and maintenance. Someone mentioned earlier having a rigger check your work...great idea. My rigger is probably giving me that exasperated look behind my back (j/k, guys) because I always have him double-check anything I've done to my system.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
tonka 2 #10 November 7, 2007 Scary. Glad your all right...that could have been really bad on landing. I know a jumper with 8000 jumps who swoops every landing and had this happen to him after a jump. He had a cheap knot tied and it came undone as we were riding back to the hanger from the landing area. Came right undone and off came the toggle....spooked him pretty good because he knew the consequences of that happening during a landing. Anywyays everyone was all right and lived to drink a beer and tell the tale. The jumper that happened to always tells everyone- "Check your gear, check your gear, check your gear!" Goes to show that even the most cautious can overlook something. So- "Check your gear, check your gear, check your gear!" Quote Share this post Link to post Share on other sites
gearless_chris 1 #11 November 19, 2007 I did the same thing with my Nitron when it was new. Right side came off when I released the brakes. Finger trapped it back on , got distracted, forgot to tie or sew it, 30 or so jumps later came off again, went to rigger and had them sewn. Ooops."If it wasn't easy stupid people couldn't do it", Duane. My momma said I could be anything I wanted when I grew up, so I became an a$$hole. Quote Share this post Link to post Share on other sites
kingbunky 3 #12 November 20, 2007 no-sew finger trap. simple to do with a home-made fid, leaves your brake lines with no knots, like a sewn trap, but it can be undone with a little patience. works great for me, your mileage may vary, i'm not a rigger, blah, blah, blah."Hang on a sec, the young'uns are throwin' beer cans at a golf cart." MB4252 TDS699 killing threads since 2001 Quote Share this post Link to post Share on other sites
