skydude2000 3 #1 August 29, 2011 Hi Guys, I have a couple questions about the electronic logbook in the alti-track. Before you flame me, I DID email L & B, and though I know their customer service is top notch, I got a speedy reply back, but it was in German. I'm having issues with the unit not recording some of my jumps. I read in the manual that it can log between 5 and 10 thousand jumps, either in freefall mode or freefall + canopy mode. I got it at jump 165, and it seems to have erased the last 80 or so jumps that I've done. I've also recently gotten into CRW, and it doesn't seem to record ANY of those jumps, even though I have it set to freefall + canopy mode. Any ideas why this might happen or what I could do to fix it? Or anyone who speaks German who could tell me what the manufacturer said? Thanks!!PULL!! or DIE!! Quote Share this post Link to post Share on other sites
skydiverek 63 #2 August 29, 2011 Are you sure it is German, and not Danish? Anyway, try this link: http://translate.google.com Quote Share this post Link to post Share on other sites
almeister112 0 #3 August 29, 2011 In terms of not recording CRW jumps, my Pro-Track doesn't record any jump where I don't get a decent delay before opening. CRW and hop 'n pops don't get logged, since the unit doesn't sense a high enough speed to switch to recording mode. Quote Share this post Link to post Share on other sites
skydude2000 3 #4 August 29, 2011 Don't know why I never thought of that, thanks. But Google Translate came up with 'I might well answer, if you do not already have the answer?' From this: 'Jeg kan godt svare, hvis du ikke allerede har svaret?' So that doesn't quite help. I'll go through the manual again and see what I can find.PULL!! or DIE!! Quote Share this post Link to post Share on other sites
Stefan_r10 0 #5 August 29, 2011 Quote 'Jeg kan godt svare, hvis du ikke allerede har svaret?' This is not german... Quote Share this post Link to post Share on other sites
Arvoitus 1 #6 August 29, 2011 Quote Hi Guys, I have a couple questions about the electronic logbook in the alti-track. Before you flame me, I DID email L & B, and though I know their customer service is top notch, I got a speedy reply back, but it was in German. I'm having issues with the unit not recording some of my jumps. I read in the manual that it can log between 5 and 10 thousand jumps, either in freefall mode or freefall + canopy mode. I got it at jump 165, and it seems to have erased the last 80 or so jumps that I've done. I've also recently gotten into CRW, and it doesn't seem to record ANY of those jumps, even though I have it set to freefall + canopy mode. Any ideas why this might happen or what I could do to fix it? Or anyone who speaks German who could tell me what the manufacturer said? Thanks!! It only records the last 400 minutes of freefall. So depending on whether you're recording canopy+FF or just FF and the types of jumps you're doing you'll have something like 50-200 last jumps saved. I have mine set for canopy+FF and it has the last 120 or so jumps recorded. One reason your CRW jumps may not be recorded is that if the dive type is set to something like freefly or something similar and then the device won't record the jump if you do a hop'n'pop style jumps, since its expecting you to have proper freefall before it will start recording. I usually have it always on SLOW. This way I have to pull really fast to make it miss the jump.Your rights end where my feelings begin. Quote Share this post Link to post Share on other sites
iluvtofly 0 #7 August 29, 2011 If you do not have it set to hop n pop mode it will not record those. So make sure you have it set to that. ETA: There is a seperate email address to speak to someone in the States who speaks English. I'm just not sure what it is. Search around the site a bit more for an American contact and you sould find it. Quote Share this post Link to post Share on other sites
skydude2000 3 #8 August 29, 2011 Thanks Iluv2fly! I'll have a look. But I'm 99.9% sure I have it set to dual mode, freefall & Hop/pop. I'll see if I can find a contact for someone in the States who can tell me how to fix it.PULL!! or DIE!! Quote Share this post Link to post Share on other sites
iluvtofly 0 #9 August 29, 2011 QuoteThanks Iluv2fly! I'll have a look. But I'm 99.9% sure I have it set to dual mode, freefall & Hop/pop. I'll see if I can find a contact for someone in the States who can tell me how to fix it. I have an alti-track and I don't think there is a dual for that. There's freefall and canopy flight...or hop & pop and canopy flight. But it needs to know if you're doing freefall or hop n pop. Quote Share this post Link to post Share on other sites
skydude2000 3 #10 August 29, 2011 Are you sure? I looked on page 34 of the alti-track manual and it says you can choose either freefall, or freefall + canopy profiles. It does say you can store more jumps with freefall only, but I read somewhere that in was in the thousand jump range, nowhere near the number of jumps I've put on it. Entirely possible that I'm reading it wrong, but I'm not sure. Now I'm also having to adjust my total # of jumps each time. Getting my info from here, on page 34: http://www.l-and-b.dk/downloads/manuals/pdf/altitrack/altitrack_man_en.pdfPULL!! or DIE!! Quote Share this post Link to post Share on other sites
iluvtofly 0 #11 August 29, 2011 QuoteAre you sure? I looked on page 34 of the alti-track manual and it says you can choose either freefall, or freefall + canopy profiles. It does say you can store more jumps with freefall only, but I read somewhere that in was in the thousand jump range, nowhere near the number of jumps I've put on it. Entirely possible that I'm reading it wrong, but I'm not sure. Now I'm also having to adjust my total # of jumps each time. Getting my info from here, on page 34: http://www.l-and-b.dk/downloads/manuals/pdf/altitrack/altitrack_man_en.pdf Freefall, hop n pop, and canopy are 3 completely different settings. You can have freefall and canopy, just freefall, hop n pop and canopy, or just hop n pop. Do you see the distinction between the 3 now? Quote Share this post Link to post Share on other sites
Pablo.Moreno 0 #12 August 29, 2011 Set the dive type on slow, and then it will record your h&p Quote Share this post Link to post Share on other sites
