gowlerk 2,296
CC_ShenanigansPeter,
Does this include cutaway housing as well?
The double housing for cutaway with heat shrink seems to free floating as well. It appears to be tacked at the top but nothing at the chest strap. Is there any reason NOT to tack similar to ripcord?
I have two of them here at the moment. Both have free floating cutaway housings at the handle end. As in if not for the shrink tubing holding them together at the end, the short one would have nothing at all holding it in place. It's probably done that way to ensure housing stays long enough under all possible loadings.
Always remember the brave children who died defending your right to bear arms. Freedom is not free.
pchapman 280
Sounds like what you saw is correct.
The Wings cutaway housing has no tack at the chest strap, unlike some other rigs. The housing is tacked up higher as you saw -- the long housing just above where it is visible in the area next the the wearer's right base 3-ring. That allows for some flexing in the short housing. I checked that on a brand new Wings a customer has at my place right now.
Some companies like some extra flex in the system, in case of hard openings etc. Eg, Vector II's used to always have a 'tack with slack' under the mudflap, that allowed the housing to move up an inch if needed. Even though plenty of older rigs had people tack the housings down in a fixed manner, contrary to RWS's design.
But that's just my general understanding and other riggers would know better about the design intent and details.
riggerrob 644
Yes Peter,
Cutaway housings on Vector 1 and 2 were slightly too short. To avoid loading the white loop, they did a special "hand-tack with slack."
Now most harness/containers use perfect length cutaway housings - to eliminate the risk of excess load on white loops. Perfect length housings do not need fancy hand-tacking .... just hand-see them in tight.
