buba07
When to flare?
Hi,
I'm four jumps into my RAPS course. I've completely fallen for this sport however in my last landing I mis judged it and was forced to come down on a concrete section of land.
Being a student I inevitably ended up on my backside and it was painfull!
When is the best indication / time to flare as I see all the skydivers and they just swoop into a standing landing?
Thanks
Thanks
Freefallphil.
Why don;t you ask your instructors about that? '
BTW landing on your backside is not recommended, a PLF will save your ass, literally ;)
Landing standing up will come in time, landing safely is way more important.
Go talk to your instructors ;)
ciel bleu,
Saskia
I'll share my own learning and experience but I'll also warn you that no matter how many instructors, coaches and fellow jumpers you ask it finally boils down to your own abilities. Others can definitely give you pointers and tips but this is one aspect of the sport that takes practice to perfect.
After a biffed no-flare landing, I began to doubt my ability to flare and flared either too high or too much. Finally after about 50 jumps or so, I have regained a lot of my original confidence in flaring. Some tips that may help
1. Look at the horizon - doesnt mean look straight ahead, but instead look at a point that includes the ground and the horizon so you can judge your height
2. I try to land in proximity to objects like wind sock, flag poles etc so that I can judge my height and apply the flare appropriately
3. Get a ladder and put it out on the landing field and climb it. Memorize the view of the height at which you want to flare. Note the size and appearance of objects in the horizon.
4. Have a friend / instructor tape your landings and review them.
5. Practice flares up high and realize how your canopy swings back when you apply the brakes. There are several ways to flare a canopy to stand still and yet several more depending on the wind conditions. I dont want to educate you on those as your instructor may disagree.
6. Practice - Practice - Practice. If you search these forums you will find a post of mine where I admit shamelessly how I loathed no-wind days. Now, I look forward to them. Practice made the difference.
Hope you do well on your next jump.
Cheers Sraja,
When you didn't flare wasn't that a really rough landing?
I think my last jump reminded me that focus is needed at all times. I suppose the sport is like learning to drive a car?
Cant wait for wednesday (next jump - weather permitting!)
I'll be back to post progress - thanks again.
Thanks
Freefallphil.
Flare before to impact. Visiting with your instructors should be first on your list. You probably have so now ill try to assist. Flare timing: is achieved with training from instructors, practice, time, and a good idea. Instructors: you know where to find them. Practice: up high in the sky after you open your parachute and do control checks or ep's. Analogy:compare a new car with good brakes to a car with bad brakes. For you both cars you'll need to figure out how much time and pressure it takes to apply the brakes. Time: is a learned thing, practice flare up high alot of times. How long does it take you to flare and feel like you pretty much have stopped and are hovering under canopy? A good idea: from visiting and gathering info about the gear your using. If you jump a 260 sq ft student canopy your 'instructors' should assist you in getting a 'good idea' on the 'timing' for the 'flare' and to 'practice' after you've opened. As you become a skydiver and jump other canopy sizes you should naturally be concerned with certain things about the canopy like 'how's good does it open' (soft/hard) how's the flare? Knowing the PLF and using it is also an asset to your a.. well, backside.
Worth repeating and emphasizing until it gets through.
My reality and yours are quite different.
Don't do that. Land with your feet under you. If you have a hard landing, better to deal with a broken ankle than a broken back or pelvis. PLF's will give you the best shot at not getting hurt when you land.
The only thing that will get this dialed in is time. But until then:
-Do not look down. Look out at a 45 degree angle.
-If there are buildings around you that have flat roofs, then when the roof disappears you're at 10-12 feet (assuming one story buildings of course.) That's a good time to flare.
-When you can see individual blades of grass, for most people that's at around 10-15 feet.
-A rule of thumb that works for some strange reason is "wait until you're really scared, then wait another 2 seconds, then flare."
As always listen to your instructors, do not take anything you read here as gospel etc etc.
<---- Low jump number! But here is my 2 cents.
Speak with your instructors but that sounds like a stall close to the ground or jumping in very strong winds.What wing are you flying?
Run this idea through your instructors:
If you are jumping a wing that can be stalled (some places have PD 9Cells or Sabre 2 for students) find the stall point during your flare practices at high altitude. It's the point where the wing will collapse. Find the lower point (just before the stall point) where the wing is stable and flying. Let's name this one slow decent point. Then, if during you flare, you find yourself in the situation where you are close to the slow decent point but still have altitude to burn stop at that point and hold it there. This way you'll land on your feet with a flying wing (less horizontal speed) and not on your back with a collapsed wing (more horizontal speed).
Lock, Dock and Two Smoking Barrelrolls!
Why don't you ask your instructors about that?
Yup...
Why o why
do people who are not qualified to give advice much less instruction insist on giving students "advice" online?
Don't they realize that their well intentioned advice could cause a person to seriously injure themselves or worse?
Why act like you know what you are talking rather than just tell a student that seeking advice from the instructors working directly with them is the best course of action?
I am beginning to understand now why they are called 100 jump wonders…
Mykel AFF-I10
Skydiving Priorities: 1) Open Canopy. 2) Land Safely. 3) Don’t hurt anyone. 4) Repeat…
Sometimes its nice to share experiences and seek advice from people in a similar position. ie someone who has just overcome the same hurdle recently. Thats human nature.
If you're blatantly bullshitting in the hope of looking knowledgable then thats wrong.
I know that I have low jump numbers :Sbut I have pretty good landings. My instructors always told me to look for the spot that isn’t moving. That will be the spot that you will be landing. The area before the spot will appear to move towards you and the area past the landing spot will look like it’s moving away.
This is what I use and it works for me. The best thing to do though is to talk to the instructors at your DZ and tell them your issue and ask one or more of them watch your landings.
El Josh
AKA ~Ruby
DS #149
Yes I only have 3 jumps...it's the magic number dude.
That's a good trick to determine where you will land but is not such a good trick to judge the flare. Indeed, the flare will make that spot move, so it's a good idea to not be thinking about it _too_ much below about 200 feet.
:S the above post doesn't make much sense :S
You know, no real informations or lessons comes with your reply.
- it can be my bad exprimation
- or my bad understandings of the phenomenon
In my limited experience the only ways that could land on your back (not ass, back) are stalling your wing close to the ground or the wind is pushing you back.
Don't read this with an aggressive tone.I just want to see why it doesn't make any sense.
True most of it is just a "feeling" at that point.
DS #149
Well, the 1000 - 600 - 300 method DOESN'T WORK. If I copy the black and white attitude that you shown here and I listen 100% to that method I over shoot land in the trees. I don't want to fly over tents or packing area and I’m not comfortable with to turning low. What I know for sure is that 1000-600-300 doesn't work. Now I'm going to hear the: well, you can take things in your own hands because after all you signed the waiver and it's your life and not our responsibility and we can only give you advices and guide lines.
OK, so suddenly the situation it's gray!! 1000-600-300 it's a guide line and not a black and white rule. Well in this case I better gather as much information as I can. This means different methods & different approaches to all the aspects of skydive. Methods like flare fast & lower vs. slow and higher. What's the down part for each method? What's the good part? Which one behaves better or leaves more room for errors if the winds drops with 10km/h 1 sec before you start flaring?
These are some cases that I've think off after only 40 jump. After 3200 jumps one could have a lot more to say about it. But not you sir!!!!!!!
Your instructors WILL tell you do flare test up there and feel the flare. You can't see shit regarding your gliding ratio up there. You don’t really know if your down speed is slow enough for landing. The only thing you feel is that you got more G load (deceleration) when you flare fast. You see the pitch angle changing a lot more when you flare fast too.
edited to remove PA's
Your right these guys do have lots of jumps and are "like schools"
But ranting and being angry isnt gonna make them help you. If you were to ask "where did I go wrong with that answer?" or "How would you have answered this?". It may have got a productive response.
There are some great articles out there regarding flare and stall points of canopies. Just gotta search for them. There's some here for starters http://www.dropzone.com/safety/Canopy_Control/index.shtml
With love in Christ
I dont intend to debate your point of view - you certainly have a lot of experience and are qualified to instruct. But here are some of my observations as a newbie
1. The points that most people share on this board are tips given to them by qualified instructors or well respected canopy pilots. For instance most of the pointers I gave were directly obtained from my instructors and a canopy seminar
2. When I had problems with my flare, I used to walk up to a world famous skydiver and ask him about it. He would give very valuable tips but something was missing - he just couldn't relate to the problems a new comer was having. After 20+ years in the sport he simply didn't have the problems I was having and his challenges were something else. A 100 jump person can maybe relate and understand the problem another low timer is having. Now I am not generalizing but I think you may understand what I mean here.
3. I'm not sure if I missed something here, but in all the posts above I have not seen something blatantly dangerous.
4. Don't all instructors go through the 100 jump wonder phase at some time in their skydiving life? I mean they don't just go from 99 to 1000.
Certainly, you have a point that well mentioned advise can be applied incorrectly and cause harm. But then why do these boards exist? Why ask a question? I think the disclaimer to all advise is well put in Bill Von's sticky as soon as you enter these forums, do we need to repeat it every time someone asks a question?
Personally, I have benefited from asking questions on this board. When I had an uncontrollable spin on level 4, when I was looking for tips on landing on a no wind day, when I was looking to buy a new canopy, when I was afraid of doing a rear diving exit and it goes on. I don't know about you but what I read here was pretty close to what my instructors told me when I asked them the same question later on at the DZ.
The post referred to doesn't make any sense, because it refers to "flying wing" without horizontal speed, and a "collapsed wing" which refers to having more horizontal speed.
Both are incorrect or at the least, very odd descriptions.
A "flying wing" (if I understand the intention) actually has greater horizontal speed, while a "collapsed wing" (again,if I understand the intention) probably refers to a flared/braked wing, which then has less horizontal speed but potentially greater vertical speed. "Collapsing" to me, anyway, describes the stall point of a canopy. The only time you want the stall point near the ground, is just prior to your feet touching.
Additionally, the post refers to how the winds may be. Flaring is very similar in no wind and high wind, the differences are how fast you flare. However, this isn't really easily explained to a low-number jumper, IMO. Otherwise, they might not flare at all in a high wind.
High winds don't mean that you adjust how much you flare. IMO (I'm sure someone will correct me) one should always flare the same, regardless of upwind, no wind, or downwind. You may finish at a different point due to speed being bled off, but the flare itself remains the same.
With jump numbers of 30 or so...I'd imagine/hope that you're still in the mode of a two (or some DZ's three) stage flare.
I really don't understand this kind of attitude. This black and white kind of attitude. This attitude brings out the worse in me.
You have someone with 3200 jump, someone that has a lot of experience and he just doesn't want to share nothing that could explain things to someone else.
I can't believe that after so many jumps one could have nothing to say or debate about flare. The classic message is: do it right and it works. It works well for all the cases that it works … but not for the others.
Listen ONLY to your instructors and don't ask nobody else!!!!! Black and white again.
Your instructors WILL tell you do flare test up there and feel the flare. You can't see shit regarding your gliding ratio up there. You don’t really know if your down speed is slow enough for landing. The only thing you feel is that you got more G load (deceleration) when you flare fast. You see the pitch angle changing a lot more when you flare fast too. So what you gather up there is flare as fucking fast as you can. IS THAT GOOD? Fuck I’ve forget, I’m asking the wrong person because you don’t care!!!!
People with experience (3200+ jump) are like schools. There are different schools with different methods and we just want to find out about them. You're school is closed because you just don't care.
Today, sir you have shown to the world and to myself that you swing a bigger penis than me.
Have a nice day.
Wow, you really put me in my place.
I apologize for being of so little assistance to others and especially for not living up to your expectations.
I will try harder, please, just give me a chance, I’ll be better, I promise I will…
Mykel AFF-I10
Sharing experiences and seeking advice is all well and good...nothing wrong with that, so far. The problem is that the one giving the advice could be dead wrong and if you go practice that advice without running it through your instructors (read: experienced, trained, knowledgable) who know you best, you could be doing yourself and your family a serious disservice.
Sorry Scoop, you are misreading AFFI totally. He IS knowledgable. Do a search and read a number of his posts.
In a PM DSE told me where was my mistake. I've writed horizontal speed instead of vertical speed. Here is reply to DSE.
Crap!!! Thanks DSE.
I've meant vertical speed. It's a professional deformation. At work we are using a weird system of conversion between 3d max and our game engine.
You know when you hold the breaks all the down and the wing collapse and stops being inflated and it shapes like U? That's what I've meant by stall point. When this happens you fall on your back. On my student canopies NAVIGATORS this never happen they didn't stall.
I've rent 1 month ago a PD9 Cell 260 while jumping at another dropzone. Up high I didn't expected for that to happen so I did one flare and didn't hold it for a few seconds. But when I've flared closed to the ground I've flared a bit higher and at 2 feet it stalled and I've felt on my back.
http://www.pulsevisuals.com/video/details/stallram-air.html
That's what I've meant by stall canopy. I was not trained about the stall and I've found out the hard way.
