humanflite 0 #1 May 11, 2013 Bit of a strange one guys as I need to put some kind of a lock on the end of a pull through cable for a car project I am working on. It currently has a lead ball on the end of it to stop it pulling through the end stop. But I need to shorten the cable and recrimp it. I was hoping some advice from riggers about how reserve cable ends are crimped to stop them pulling through the reserve handle. The cable I am working with is not quite as beefy as a reserve cable, but I am hoping to use the same approach if I can do it pretty cheaply!! thanks Quote Share this post Link to post Share on other sites
Jeffrey 1 #2 May 11, 2013 Nicopress® Swage Fittings [/url]https://www.google.com/search?q=Nicopress%C2%AE+Swage+Fittings&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a[url] Quote Share this post Link to post Share on other sites
Slurp56 0 #3 May 12, 2013 The tool I see used most frequently is a hand swager by Loos & co. I'm not sure of the price, but its probably a bit more than you want to spend if you're only doing 1 cable. If it's a smaller diameter cable, you might check with your local bike shop, they have tools for manufacturing shifter and brake cables with swaged ends. http://loosnaples.com/swaging-machines/locoloc-m1-type-i-________________________________________ I have proof-read this post 500 times, but I guarantee you'll still manage to find a flaw. Quote Share this post Link to post Share on other sites
JohnSherman 1 #4 May 12, 2013 Parachute ripcords ball ends are crimped with multiple blows from a 10 ton press. They are tested with 300 pound force applied for 3 seconds, No movement is allowed. This process produces a joint which is rated at 80% of the cable strength of 920 pounds. We routinely get 100% of cable strength. Might I suggest a Ball and Shank termination? Most aircraft repair shops have hand tooling which will do the job. They might even have some Ball Shank fittings in stock. JS Quote Share this post Link to post Share on other sites
normiss 889 #5 May 12, 2013 Since it's for cars...and no need for TSO priced hardware.... Custom cables are easy on car projects. cable stops Quote Share this post Link to post Share on other sites
dpreguy 14 #6 May 13, 2013 Rather than buying a long armed swaging tool, you can go to a West Marine store. They sell cable in several sizes and they also swage fittings onto the cables, but may not have an "end' sleeve. Maybe go to Ace Hardware and get a cable - "end" - swage. I think they are aluminum. About $3 bucks. Then go to the West Marine and have them swage it on for you. Quote Share this post Link to post Share on other sites
demon4o7 0 #7 May 13, 2013 When I break a clutch cable, I use silver solder. Make a new "stop" and solder it on, lasts a while. Quote Share this post Link to post Share on other sites
humanflite 0 #8 June 1, 2013 thanks for all the input guys :) Quote Share this post Link to post Share on other sites
