hypoxic_fool 0 #1 May 31, 2013 i jump a sabre 1 and of course experience, more often than not, hard fast openings. i have read that a larger slider (32x29) could fix the problem. just wondering if anyone has used this method and or knows where i can obtain one. Quote Share this post Link to post Share on other sites
JerryBaumchen 1,430 #2 May 31, 2013 Hi fool, Quoteknows where i can obtain one I recommend that you contact this guy; I am sure he can build you almost any type of slider that you might want. Mark Lancaster Skyworks Parachute Service 2222 Buffalo – West Springs HiWay Buffalo, SC 29321 864-429-8428 skyworksparasvc@aol.com I would suggest that you contact Mark & discuss what you want and he/you can work out what solution best fits. JerryBaumchen Quote Share this post Link to post Share on other sites
hypoxic_fool 0 #3 May 31, 2013 thanks for the info jerry. i could probably also have my local rigger, rory corrigan, rig me up a pocket slider. but im curious what others opinons are on the matter. Quote Share this post Link to post Share on other sites
monkycndo 0 #4 May 31, 2013 I have jumped Sabres for years. I love them for wingsuiting. If you have one that opens a bit too briskly, I suggest a pocket and I'm sure Rory can hook you up. If you are due for a reline, I suggest going coated HMA. The added friction of the lines will slow the slider ever so slightly for a much better opening. MEL (masterrigger1) or Pete (PeteS) can make you a line set. Have had great luck with those two options.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
DBCOOPER 5 #5 May 31, 2013 My opinion is get rid of it before it really hurts you. You asked.Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
teason 0 #6 May 31, 2013 Is the opening harder when it stands you up or does it push you down into the harness afterward. Larger slider will increase the first and reduce the second, smaller will do the opposite and give you the snivel-whack. It's a trade off between the two. I would check line trim first as spectra brake line can shrink over time and change the opening characteristics. I've had a saber since '93 on some line sets hard openings have been indicative of trim issues.I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
PiLFy 3 #7 May 31, 2013 Here's a useful link for you: [Url]http://www.dropzone.com/help/Classifieds/Classifed_Ad_Listing_Guidelines_527.html[/url] Quote Share this post Link to post Share on other sites
hypoxic_fool 0 #8 May 31, 2013 teasonIs the opening harder when it stands you up or does it push you down into the harness afterward. from what iv seen, there's very little snivel, and then a fast opening leaving my canopy with a boomerang shape for just a second or two. the canopy is slightly out of trim and could use a new line set sooner rather than later. im mainly going by this video iv seen here http://www.youtube.com/watch?v=6dLU9Umaz5g id love for my openings to look like that second one.. also i was not aware that the trim of your canopy had such a drastic affect on opening characteristics. Quote Share this post Link to post Share on other sites
hypoxic_fool 0 #9 May 31, 2013 DBCOOPERMy opinion is get rid of it before it really hurts you. You asked. i did, and i should. Quote Share this post Link to post Share on other sites
hypoxic_fool 0 #10 May 31, 2013 monkycndoI have jumped Sabres for years. I love them for wingsuiting. If you have one that opens a bit too briskly, I suggest a pocket and I'm sure Rory can hook you up. If you are due for a reline, I suggest going coated HMA. The added friction of the lines will slow the slider ever so slightly for a much better opening. MEL (masterrigger1) or Pete (PeteS) can make you a line set. Have had great luck with those two options. thanks for the tips, i will keep them in mind. glad to know that not only newbies are jumping these things.. Quote Share this post Link to post Share on other sites
teason 0 #11 May 31, 2013 A thought just occurred, jumpers often change sliders to tweak openings. Sounds like you my befit from a larger slider but don't assume your current slider is a factory original. Talk to PD first to get the specs to make sure it wasn't replaced with a smaller one. A slider that is too small will actually start to move down the lines with only center cell inflation. That allows premature cell inflation and the small area won't resist the wind. A slider is generally the size of the distance between the b and c lines by the width of the cell.I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
SEREJumper 1 #12 May 31, 2013 I second a slider from Mark and Skyworks. He makes a domed slider that works great and I can see the advantages of the same openings due to it replacing the existing slider and its not just an add on pocket that could/could not function the same way every time. Definitely want to make sure any canopy is not to far out of trim for the best openings you can get.We're not fucking flying airplanes are we, no we're flying a glorified kite with no power and it should be flown like one! - Stratostar Quote Share this post Link to post Share on other sites
Martini 0 #13 May 31, 2013 This issue has been discussed many times here. All of my Sabres have been great openers. Some people have had very bad experiences with Sabres. Packing is an issue. Line trim is an issue. The 170 is a notorious bad boy, possibly/not because it uses the same slider as a 107. I have a Sabre that I put a larger slider on to improve the openings, it opens even better with the original slider and......a new line set. Since you know it's out of trim I'd start with a new line set. Or, if you're feeling really brave, stretch the lines according to Brian Germain's method. I use it, others consider the technique to be dangerous. That's a separate issue. See how much fun this is?Sometimes you eat the bear.............. Quote Share this post Link to post Share on other sites
jockbauer 0 #14 May 31, 2013 DBCOOPERMy opinion is get rid of it before it really hurts you. You asked. +1 I used to almost dread my openings every jump on my Sabre 1. Just switched to a Sabre 2 and my troubles have gone, love my new canopy Quote Share this post Link to post Share on other sites
RMURRAY 1 #15 May 31, 2013 for any sabre 1 that hints at opening hard, I would get a dome slider from MEL right away. the way he explained to me a long time ago a pocket slider can 'stand on edge' and still open hard. a dome slider is balanced and more reliable. Quote Share this post Link to post Share on other sites
hypoxic_fool 0 #16 May 31, 2013 RMURRAYfor any sabre 1 that hints at opening hard, I would get a dome slider from MEL right away. the way he explained to me a long time ago a pocket slider can 'stand on edge' and still open hard. a dome slider is balanced and more reliable. thanks, im going to contact him imidiately Quote Share this post Link to post Share on other sites
DcloudZ 0 #17 May 31, 2013 I've got around 40 jumps on a Sabre 1 (Yes, I understand that this is REALLY not a lot) But I have not had a single hard opening. Perhaps it's the canopy, but it can also be the packing method. When I pack my sabre I make sure I keep everything controlled and flat. After counting my cells I take the first 3 cells from one side, roll them up and put them in the 4th cell and do the same from the opposite side. Haven't had any problems with this method... Try it out?"Better to have a short life that is full of what you like doing than a long life spent in a miserable way." -Alan Watts Quote Share this post Link to post Share on other sites
uberchris 0 #18 May 31, 2013 peteS installed a pocket on my slider for what it would cost to get drunk on malt liquor for the weekend. long snivel, but best few bux i ever spent. talk to any riggergravity brings me down......... Quote Share this post Link to post Share on other sites
Hellis 0 #19 May 31, 2013 DcloudZI've got around 40 jumps on a Sabre 1 (Yes, I understand that this is REALLY not a lot) But I have not had a single hard opening. Perhaps it's the canopy, but it can also be the packing method. When I pack my sabre I make sure I keep everything controlled and flat. After counting my cells I take the first 3 cells from one side, roll them up and put them in the 4th cell and do the same from the opposite side. Haven't had any problems with this method... Try it out? Another way of rolling the nose is to roll the upperskin inside each cell. So that way you "remove" the overhang of the nose and therefore not inflating. DISCLAIMER: I have not tried this on a skydivingcanopy. Only on a vented BASEcanopy. Quote Share this post Link to post Share on other sites
davelepka 4 #20 June 1, 2013 Quotethanks, im going to contact him imidiately If your lines are out of trim, the new slider is a maybe/maybe not solution, and possibly a maybe-not-for-long solution. Consider buying another canopy. The slider will run you upwards of $100, and a new line set installed will run you into the $300/$350 range depending on which way you go. You'll be into it for more than it's worth, and out of pocket upwards of $400. Sell it off cheap, like $200 or $300. Disclose that it does sometimes open hard like a Sabre does, and if someone needs a dirt cheap canopy, they can buy it and you're 'clean' as you told them the whole story. Maybe a rigger will grab it as a wingsuit or backup canopy, and they do the all the work to it for no cost. Take that, and the money you would have spent to 'fix' it and buy something newer that doesn't have a reputation as a slammer. Quote Share this post Link to post Share on other sites
hypoxic_fool 0 #21 June 1, 2013 davelepkaQuotethanks, im going to contact him imidiately If your lines are out of trim, the new slider is a maybe/maybe not solution, and possibly a maybe-not-for-long solution. Consider buying another canopy. The slider will run you upwards of $100, and a new line set installed will run you into the $300/$350 range depending on which way you go. You'll be into it for more than it's worth, and out of pocket upwards of $400. Sell it off cheap, like $200 or $300. Disclose that it does sometimes open hard like a Sabre does, and if someone needs a dirt cheap canopy, they can buy it and you're 'clean' as you told them the whole story. Maybe a rigger will grab it as a wingsuit or backup canopy, and they do the all the work to it for no cost. Take that, and the money you would have spent to 'fix' it and buy something newer that doesn't have a reputation as a slammer. well, the plan was to jump it until im ready to downsize to a 150 then buy a new or slightly used sabre 2 150. i got the canopy for a case of dos equis.. and cannot justify selling it for any cash. id like to reline it when its completely nesscesary, then sell it for less than it cost to reline it once im done with it. i cannot currently justify asking any money for it and that would put me back at square one. i just find it hard to beleive that this canopies openings cannot be tamed. there has got to be a way, or so i hope. Quote Share this post Link to post Share on other sites
Martini 0 #22 June 1, 2013 You haven't mentioned how many jumps are on the current line set, you do say that you know that it is out of trim. A domed or pocketed slider will not give you a canopy that is in trim. There are a ton of old Sabres out there with original linesets that would be fine if relined, they sit unused because they open badly. The canopy, if in good flying condition, is worth at most $600, investing $300 might not be a good plan. All canopies will eventually need lines replaced though and at some point every canopy will need to be retired. Your rigger should be able to help you make a decision.Sometimes you eat the bear.............. Quote Share this post Link to post Share on other sites
hjumper33 0 #23 June 2, 2013 I love me a good sabre 1. I just roll the crap out of them when im not wingsuiting, and they seem to open fine. if anyone has an old 120 or 107, im always in the market. Quote Share this post Link to post Share on other sites
NovaTTT 2 #24 June 2, 2013 There's good advice here, Hypo, and certainly if the lines are good the oversize slider can help. In my experience with S1s, packing is key and the Nova Pack (outside four into the center cell) is the best way to tame the openings. Just roll the shit out of the outer four and stuff them deep into the corresponding side of the center cell. Then wrap the tail and proceed as usual. I was introduced to this method back in the day after having some really bad openings despite careful packing.- and it worked tremendously well. After adopting it I never had less than a comfortable opening with my Nova. Please report back your findings and experiences. N"Even in a world where perfection is unattainable, there's still a difference between excellence and mediocrity." Gary73 Quote Share this post Link to post Share on other sites
cdhezel 0 #25 June 2, 2013 ..before modifying try variations on the pack technique I used to jump a German canopy that was basically a copy of the Sabre, I resolved the hard opening problem by rolling the nose a bit tighter and more when packing, increased snivel time but made a big difference when opening,When I go, I want to pass away in my sleep, just like my dear old Grandmother, NOT screaming like the passengers in the car she was driving. Quote Share this post Link to post Share on other sites
