Rhonda66
Question for Skydiving Pilots
Hi -
I'm learning to fly in a C-152 out of Bedford, MA and I should be soloing this month after I get my medical certificates on the 12th.
My husband asked me today if I would be able to let him jump from the 152 after I get my PPL under any circumstances.
My questions are -
1. Would he be able to jump with me as a certified private pilot if we filed the appropriate paperwork with the FAA? Would I need a minimum number of hours or a special rating? I'm sure there are all sorts of issues involved here so any info. would be appreciated...
2. Is it possible to get out of a 152 that doesn't have a door that's modified for skydiving?
I'd have to find out if they would even allow it in a rented 152 and they probably wouldn't, but I'm just curious if anyone has ever flown jumpers somewhere other than a drop zone or demo event and how complicated it is to do that legally...
Thanks,
Rhonda
Rhonda
PP ASEL
to answer ur question i have a friend who has jumped from a cessna or two in flight with the normal doors and he says it's tough to push against the wind but apparently he was able to do it.
When the park ranger showed up and asked who the pilot was he just said "i dunno i just hitched a ride"
lol
EDIT: He also took the passenger side door off as well. (as another solution.) Said it was pretty easy to remove and put back on. From my own personal experience with 152's the worst thing is how little room there is sitting in the seat once u have ur rig on! ;)
If you go through all the steps, it's legal but I personally wouldnt do it. I'm not a jump pilot by the way, just a 172 driver. If you yaw a little to the right I don't think it would be too hard to open the door enough to jump, but there would be plenty of stuff to snag on and everything. Just doesn't seem worth the risk to me.
Dave
That's the thing - I find it hard enough to get in and out of on the ground...but he thinks he can do it and if he says he can, then he probably can...I wouldn't mind letting him try sometime after I get my PPL and am comfortable with trying it, but I want to know if it's something we can even consider doing...
Thanks.
Rhonda
PP ASEL
I've jumped out of 150s several times, one an Aerobat with the door on but still easy to push; as I recall, it didn't have a window. If you want to take the door off, you need to get a piece of paper from the FAA that says it's o.k. ; there's a list in the Advisory Circular in the back of the SIM of planes that can get such approval, but I suspect the place you're renting would frown on it.
HW
From what i know of FBO's who rent, if you get caught you will never rent there again.Also i would get a few more hours after your Private before you even attempt to try flying jumpers.Just my opinion,as a helicopter pilot i am always being asked to fly jumpers, Sometimes i do, sometimes i dont, but dont let anyone pressure you into doing something you are not ready for....just like skydiving.
Hi Rhonda,
Ok.......Cessna 152/150 jump plane = Bad Idea.
Here's why: You will have just over the minimum hours required for the PPL. This is not a lot of experience to draw from.
Do you plan to fly with a bail out rig? The doorway is so small and awkward that the possibility of a premature deployment is very high. If that happens then it would very likely go over the tail and take it off or damage it to a point beyond your experience level to deal with. "Should I stay or should I go now?"
To do it legally you would need to get the airport owner's/land owner's permission to do skydives over it.
Do not drop over a congested area. That can be defined by one farm house and barn.
You have the FAR about creating a hazard by dropping objects.
Go to my site and read the FARs on skydiving and the Advisory Circulars there. It should help educate you some things.
Do you own the aircraft? You risk losing your insurance if they have not been notified that you want to use the plane for skydiving. If you're renting the plane then you risk the chance they will never rent to you again.
But I would say the hazard to your life and your husbands is much greater trying to do this than any legal problem you could have.
Chris Schindler
www.diverdriver.com
ATP/D-19012
FB #4125
Congratulations on learning to fly!
You can throw him out of the plane legally as long as you don't charge him for it. You aren't prevented from dropping skydivers, as long as none of them are paying, and you aren't being compensated.
They probably won't allow it in a rented plane, period. I would agree with Chris, a 152 is not a good jump plane, especially if it doesn't have the correct door. If you really want to drop someone I would get your license, then go get your high performance endorsement, preferably in a 182. You might be able to work something out with a local DZ to drop someone. Essentially you would be renting their plane for the jump.
Hey Howard -
Somehow it doesn't surprise me that you've done it ;)
You know Adrian and if he thinks he can do it, I'm sure he can get out without taking the plane down with him...
Chris, I wouldn't do it until I was quite experienced. I'm a pretty conservative person so I wouldn't do it right after I got my PPL, but we want to know if we can even consider it later. Not that we don't love Jumptown of course, Howard :ph34r:
I'm sure that it would be an issue with a rented plane, but if I really love flying still after I get the PPL then I may consider purchasing a 152, especially if Adrian can jump out of it too...anything larger and equipped for skydiving purposes is going to run way out of my price range...
The place he wants to jump into isn't conjested and is a large field that has a bigger landing area than some DZ's we've jumped at. It's a field where we fly R/C aircraft...
Thanks B|
Rhonda
PP ASEL
Rhonda,
Again, I really hope you do not use a 152 for jumping. I'm 6' and skinny as hell and without a rig I'm jammed in there. Getting the seat back enough to swing out and roll out the door would be tough.
I know you want to believe in your husbands ability to get out without taking the plane down but I still strongly recommend not using a 152 (even if all else is approved) for jumping from.
If you want to keep the cost of purchase down I would recommend getting a Cessna 172. They are approved for flight with the door off. I would have to look further to see if a 337 is required in the aircraft paperwork to actually take the door off and fly. I also want to reiterate that the insurance company may not like it at all. Most insurance companies I know require 500 TT and 50 in type to fly jumpers. I'm not sure if they would agree with insuring you for the sole purpose of flying only your husband.
As far as renting a 182 from a local jump club I don't think that would work out either again because of the insurance thing.
Sorry to be a wet blanket here. Just trying to give the most amount of information to keep you safe and legal.
Chris
"Diverdriver" brings up many good points about not using a 152 and forgive me if this has already been brought up, but what about the aircraft's performance? I have never flown a C-152, but I did train on C-172Ps (which are the 160hp version) and with myself and my instructor on board, climbing to altitude was occasionally a challenge on the hot high density altitude days. Heck even the new C-172Ss that I occasionally fly can be challenging to get to altitude with any sort of weight on a hot high density altitude day. I would only be comfortable flying a C-182 (or better) if I was to think about ferrying ski divers to altitude. But I won't be doing that anytime soon as I only have 150+ hours and must rent from an FBO. Besides, now that I've passed my AFF course, I want to jump out of the airplane (though I still plan on staying current with a couple of flights a month). :P
Try not to worry about the things you have no control over
Hey -
You're not a "wet blanket" - I appreciate the info.
I don't see all that much difference between doing it with a 152 and a 172 - you have more room in the back of course, but not too much more in the front and we're both fairly small - about 5'5", 135-140 pounds each and he jumps a 107 so I don't think weight would be a huge issue. Myself, I find I have alot of room in the cockpit and always have to move the seat way up to reach the rudder/brake pedals and I usually still can barely reach them with the seat all the way forward so I could wear my gear comfortably and still be able to fly. You still have to deal with getting the door open (unless you take it off) and getting out without a step.
Hypothetically, let's say it's a 172 anyway then since it would only take a few hours to get checked out in the 172s according to my CFI, and I was to get in a considerable amount of hours in the 172 - would you do it then?
I was surprised that skydiving isn't included the list of "do not do's" on the rental agreements from my flying club - They say no aerobatics and no passengers for hire, but it doesn't specifically say no skydiving...
Rhonda
PP ASEL
I always figured the easiest way to do it in a 172 (with the door on) is to have the jumper sitting in back and someone else up front to hold the door open. It's kind of a tight squeeze getting out of the back but I think it could be done that way. Not sure how hard it would be to push the door so I don't know how necessary a 3rd person would really be. I'd be most worried about all the snag points around the doorway. But if it looks safe to you and your husband and you really wanna do it, I'm sure it's possible. If you're renting, or if you aren't sure about your insurance covering it and all that, you can either try to get the proper permissions or just go ahead and risk it. Just be aware of the consequences. After getting your license, take your husband up and have him open the door to see what it's like. Might change both of your minds.
Dave
Hi -
I said before I'd either buy my own aircraft or talk to them first - if I was a complete schmuck, I'd just do it and not even be out here asking, right? I'm sure there are plenty of jumpers who have done just that ;) I just said I was surprised it wasn't specifically included in the agreement...
Rhonda
PP ASEL
