Rickendiver 6 #1 September 14, 2013 Trying to figure out WTF is going on with my rig. I’ve had 3 openings where it felt like maybe one of the risers was hanging up, followed by a HARD opening canopy. The last one riser whipped the shit out of me so much I was seeing stars for a little while under canopy, and I was lucky to land OK. My Rx Bobsters weren't so lucky, & my helmet has a nice gash in it. I’m jumping an Infinity I-44 with a Pilot 168 that I’ve packed the same way for 140 jumps with no drama of any kind until this. A couple of riggers at the DZ looked at my rig & didn’t see anything obvious. Riser covers seem to release OK on the ground. BTW-May be unrelated, but this all started happening right after my last reserve repack. Quote Share this post Link to post Share on other sites
riggerrob 643 #2 September 14, 2013 " ... May be unrelated, but this all started happening right after my last reserve repack." ................................................................................. You just answered your own question. Different riggers pack more or less canopy into the top corners of the reserve container. Too much - or too little - bulk can change the geometry of your main riser cover tuck tabs. Quiz your local riggers again. Ask them if they pack -or less - bulk in the top corners than your last rigger. Quote Share this post Link to post Share on other sites
SEREJumper 1 #3 September 14, 2013 Try a medium height (enough to reach terminal) solo belly jump with your riser covers open and see if you openings are better.We're not fucking flying airplanes are we, no we're flying a glorified kite with no power and it should be flown like one! - Stratostar Quote Share this post Link to post Share on other sites
Rickendiver 6 #4 September 14, 2013 Thanks, I'll do that. I've used the same rigger since I bought it new, and this is the second I & R he's done on it. Maybe he did something different this time. One thing I just noticed on my rig is that the risers, when stowed do not reach past the reserve pack tray. Is that problematic? Quote Share this post Link to post Share on other sites
Rickendiver 6 #5 September 14, 2013 Thanks - But the openings in between the bad ones are all normal & good. After slammer #2, I changed my packing method to include double wrapping the grommet stows & routing the main risers over the intermediate tab instead of directly on top of the reserve risers. Then 14 great openings before slammer #3. This one nearly ended me. The last thing I remember before lights out was some really intense back pain & getting bashed in the face. Still can't use some of my fingers! Quote Share this post Link to post Share on other sites
davelepka 4 #6 September 14, 2013 What do you do with your lines when they exit the bottom of the riser trough and come into the main pack tray? What you should do is have them continue straight down in the same direction all the way to the very bottom corner of the pack tray, then make a 90 degree turn in toward the middle of the pack tray, with the left and right ends meeting up in the center. The whole time, the lines are following the seam of the bottom and sides of the pack tray. Once they meet in the center, they join up as 'one' again, and the remainder of the line up to the last stow on the bag can then be coiled up on the floor of the main pack tray. Does that make sense? Here's why I mention this - what you don't want to do is have the lines make a 90 degree turn coming out of the riser trough and meet up in the center of the seam between the bottom of the reserve container and the floor of the main pack tray. The reason is that if the bottom of the reserve container is 'overhung', meaning that it's not a perfectly flat, vertical wall coming up from the floor of the main pack tray, and you run you lines under that overhang, they can get caught under there on the way out and it would feel just like a riser cover not releasing. On side would be free to unstow, and the other would hang up for an undetermined amount of time. Even if you don't deliberately tuck your lines up under there, if you don't deliberately route them straight down to the bottom corner, you stand a chance of them getting hung up. You mentioned a fresh reserve repack and being the only new factor, so your lines might be an area to look into. And yes, you should have enough unstowed, free line to make it all the down to the bottom corner, across to the middle of the container, and then still have a little slack before the last stow on the bag. With regards to your riser covers themselves, I had some hang ups early on with my Infinity (like in the first 20 or 30 jumps), and this was on a Velo loaded up at 2.5 to 1, and I never had any problems with the openings aside from feeling a 'bump' in the process. You describe being hit with the risers in various places, so I'm thinking that you're getting tossed around pretty good before the riser releases, and I just don't think a riser cover would do that. With one riser cover open and one closed, the difference in length is not sufficient to create that type of leverage to move you around that much, especially with a rig that has 140 trouble-free jumps in the bag. Now if one riser (or line group) was hung up under the corner of the reserve container, that another story and a difference between the risers 4 or 5 times greater than a hung riser cover. QuoteI changed my packing method to include double wrapping the grommet stows FYI - tighter line stows will not slow down your opening. If the lines are tight enough that they cannot 'fall' out of the bands, that's good enough. As long as they stay in place long enough to allow proper staging of the deployment, they're doing their job. You're not going to be able to make a rubber tight enough to slow the pilot chute, and even if you did, it's the pack job inside the bag that makes the opening, not the speed at which it get's to line stretch. Note that many manufacturers now offer D-bags with locking stows only, and a pouch to hold the loose, coiled lines that remain. There is zero drag on the PC from the lines as they play out of the pouch, and people report great openings with these bags. Quote Share this post Link to post Share on other sites
Rickendiver 6 #7 September 14, 2013 *** You describe being hit with the risers in various places, so I'm thinking that you're getting tossed around pretty good before the riser releases, and I just don't think a riser cover would do that. With one riser cover open and one closed, the difference in length is not sufficient to create that type of leverage to move you around that much, especially with a rig that has 140 trouble-free jumps in the bag. Now if one riser (or line group) was hung up under the corner of the reserve container, that another story and a difference between the risers 4 or 5 times greater than a hung riser cover. This is really making a lot of sense - I'm looking at the reserve pack tray, and seeing a few wrinkles in the corners where lines could catch on, where perhaps before the last reserve repack the bulk may have been distributed to more fill the bottom corners. I'll be sure and route the lines as you described from now on! If I did this right, there should be a pic attached showing where my risers sit in relation to the reserve pack tray. Not sure if this may be contributory to the lines snagging. BTW- Thanks to you and everyone else for taking time out of your day to help me on this Quote Share this post Link to post Share on other sites
hookitt 1 #8 September 14, 2013 I'll pack and jump your rig next week if you're there. We'll sort it out if there is a gear issue. If you don't go next weekend, arrange for me to get your rig. I could use a second rig for the day anyway I've looked at this rig and there is nothing obvious. The canopy is distributed well and it's not over stuffed in anyway. When you're able, I'll watch you pack just so I know exactly what you do. I know you pack fine however I've never watched directly so let's do that and I'll go take a beating for you :D My grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto Quote Share this post Link to post Share on other sites
Rickendiver 6 #9 September 14, 2013 Thanks Tim! You're awesome, man Quote Share this post Link to post Share on other sites
JerryBaumchen 1,372 #10 September 14, 2013 Hi dave, QuoteThe reason is that if the bottom of the reserve container is 'overhung', meaning that it's not a perfectly flat, vertical wall coming up from the floor of the main pack tray, You and Ricken both have Infinitys. I am not sure that your 'overhung' means, but the bottom reserve wall of an Infinity reserve container ( the wall that seperates the reserve container from the main container ) slopes upward towards the top of the reserve container. You mention: " . . . vertical wall coming up from the floor of the main pack tray . . . " We are dealing with a non-rigid material; fabric. It really never comes up vertically on any rig; but the design of an Infinity is that it does slope upward. Just so he understands ( I hope ), JerryBaumchen Quote Share this post Link to post Share on other sites
RMURRAY 1 #11 September 16, 2013 was speed at deployment time a factor? PD has a good summary of the items that can affect hard openings. http://www.youtube.com/watch?v=cVAoiLl2B6M Quote Share this post Link to post Share on other sites
