Chris-Ottawa 0 #1 April 9, 2014 So, I'm looking for a mudflap mount and can'tfind much more info than a couple threads on how to make these yourself, or some of the safety implications, but nothing comparing the two (or other options I'm not aware of). So, really simply, should I buy the Wedge, or the Altimount or another alternative....and why? Wedge:http://www.chutingstar.com/skydive/wedge-mudflap-altimount Altimount:http://www.chutingstar.com/skydive/altimount Thanks!"When once you have tasted flight..." Quote Share this post Link to post Share on other sites
verdi 2 #2 April 9, 2014 i have a wedge ... i like the softer design ... Quote Share this post Link to post Share on other sites
colossus 0 #3 April 9, 2014 I have a wedge as well. Thinking about it, and seeing the other design... if for what ever reason I had an impact upon my chest, I would rather have the wedge collapse, and hopefully not break a rib vs. the metal AltiMount. At least that was my logic between the two. Quote Share this post Link to post Share on other sites
voilsb 1 #4 April 9, 2014 The Altimount is carbon fiber, not metal. It's easy to file it such that the bend is weak, and I've had one break off from a light freefall bump during a horny gorilla. I also use a plastic one made by user monkycndo (http://www.dropzone.com/cgi-bin/forum/gforum.cgi?username=monkycndo;). His are very inexpensive, and they're designed to bend on impact.Brian Quote Share this post Link to post Share on other sites
ChuckMartin 0 #5 April 10, 2014 I have had one the the bonehead ones on my rig for about 350-400 jumps now and love it. No problems with it so far but it has not taken to many hits either. Quote Share this post Link to post Share on other sites
pchapman 279 #6 April 10, 2014 One wonders if anyone is building triangular foam mounts, similar to the chest strap mounts of the 80s... Quote Share this post Link to post Share on other sites
monkycndo 0 #7 April 10, 2014 Brian, thanks for the plug for my mount. Glad you like it. Chris, if you go with the chest strap wedge, get the long version. It won't bend backwards when flying a WS. Or you can just order a mudflap mount from me. I also have a custom mount for the AltiTrack that allows you to see the digital display without removing the alti from the mount. 50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
Deimian 43 #8 April 10, 2014 L&B have their own wedge. Useful is you have a viso. https://www.lbwebstore.com/wedge-mount.html Quote Share this post Link to post Share on other sites
Chris-Ottawa 0 #9 April 10, 2014 Thanks everyone! You all basically confirmed my suspicions that I was able to gather from the photos and info on chutingstar and the manufacturer's website that the Wedge seems like the safer option as far as crashing goes, but they wil both serve the purpose. Deimian, have you used the Viso Mount? I'll be using my Viso for wingsuiting instead of trying to look at my wrist, but I suspect that the chest strap mount might allow it to fold under, or move etc. I like the idea of a mudflap mount, but then I have a slight issue with packing, not that I'm too worried though. To anyone with the wedge: I have a Viso that I'll be mounting to it, but do I need the Digital Alti pouch to attach it, or can I mount it directly to the flap? I'd really like to avoid the pouch, but it seems that this would be my only option for the Viso. Thanks again!"When once you have tasted flight..." Quote Share this post Link to post Share on other sites
Deimian 43 #10 April 10, 2014 No, sorry, I didn't use it. I just knew that it existed and thought you might be interested. Quote Share this post Link to post Share on other sites
DBCOOPER 5 #11 April 10, 2014 They are good, safe GoPro mounts also... http://youtu.be/oI8ClGakblUReplying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
colossus 0 #12 April 10, 2014 I have a visio on my wedge. What I did was I made a velcro sandwich, and sewed the visio mount to the sandwich. Then, I well... put the sandwich on around the top of the mount. It holds well, and allows for the relatively easy removal when I have to change the visio battery (which I have to do this weekend). I have also had a Galaxy alti on there, and again it had a plate that was held by screws on the inside of the wedge's triangle. IMHO, it was simple and secure. Quote Share this post Link to post Share on other sites
jurgencamps 0 #13 April 11, 2014 You can mount it without using a pouch. I just use 4 small straps. See orange arrow and circles in the picture in attachement. I do not have a picture of my setup here at hand. Quote Share this post Link to post Share on other sites
