Papcio 0 #1 May 10, 2014 Hello Skydivers As i am pretty new in Business an i want to buy a skydiving computer. As you know there is few different ones and that is why i am asking you which is the best and why? Thank you for advice. Quote Share this post Link to post Share on other sites
CaptnCrunch 0 #2 May 10, 2014 PapcioHello Skydivers As i am pretty new in Business an i want to buy a skydiving computer. As you know there is few different ones and that is why i am asking you which is the best and why? Thank you for advice. Hey Papcio, i have a L&B SOLO in my helmet and use additionaly the N3-AUDIO. The N3 requires you to wear Earbuds, it will "talk" to you during freefall and tell you "10-housand, 9 thousand .. and so on every 1000 ft, until it yells at you "DEPLOY". To me this is a great thing, i heard others that would not like it - a nice extra (although i never used it) is you can patch Music into that N3 Audio and listen to Music - most people i have heard think it is a BAD IDEA - i would maybe do it in a high pull and only if i know i am the only one up there. The N3 Audio also logs all your Jumps, and you can import them to "Paralog" as a electronic Logbook, it however has NO VISUAL ALTIMETER / it just does AUDIBLE If you just look for a "beeper" you cannot go wrong with the L&B Solo II - easy to set and very small - if fits in tight spaces and is loud ! Quote Share this post Link to post Share on other sites
councilman24 37 #3 May 10, 2014 Para-alert! Still works after 33 years! I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
Trafficdiver 8 #4 May 11, 2014 I have a pro track. Gives me three alarms and record all of my jumps, keeps dtailed records of 20 or so. Works every time I've turned it on ...now I just leave it on all the time. Quote Share this post Link to post Share on other sites
skydivex3m 0 #5 May 11, 2014 I use L & B SoloII, OptimaII and Quattro. -The SoloII gives you a basic dytter, with 3 freefall alarms. -The OptimaII gives you 3 freefall alarms and 3 canopy alarms that works as a guide for your landing pattern, and your swoop setup when (if) you wanna get into that some day. You can also set things like volume, and it has the option of setting up different altitudes for different jumps, save them, and easily select on the way to altitude. - The Quattro is basically the OptimaII with an extra free fall alarm. All these dieters turn on automatically when the plane starts climbing on your first load of the day. Hands down best products and by far the best customer service in the industry!https://icarusanddaedalusadventures.blogspot.com/ Quote Share this post Link to post Share on other sites
Deimian 43 #6 May 11, 2014 skydivex3m All these dieters turn on automatically when the plane starts climbing on your first load of the day. Careful with that. None of them "turn on" when the plane starts climbing: -Optima II (and I think Solo II as well, but I didn't check it) will switch to "airborne mode" when the plane starts climbing, if it was already on. The screen will turn off after 14 hours, but the device will still be turned on. If you turn it off manually it will not turn on/switch to airborne mode automatically on climbing. -ProTrack will switch to "airborne mode" when the plane starts climbing, if it was already on. In automatic mode it will never turn off automatically. In economic mode it will turn off automatically after 14 hours. If the device was turn off (either automatically when in eco mode or manually) it will not turn on/switch to airborne mode automatically on climbing. As a side note, regardless of how you operate your devices, I think it is a good idea to check them before getting into the airplane and not just assume that they'll work "automagically". Quote Share this post Link to post Share on other sites
