tsalnukt 1 #1 May 16, 2014 Can someone please tell me the purpose of offsetting the grommets on the main packing container?? the whole thing always looks cockeyed to one side. Is there an actual purpose or is it an overcomplicated solution to some problem??? Quote Share this post Link to post Share on other sites
theonlyski 8 #2 May 16, 2014 tsalnuktCan someone please tell me the purpose of offsetting the grommets on the main packing container?? the whole thing always looks cockeyed to one side. Is there an actual purpose or is it an overcomplicated solution to some problem??? If it looks cockeyed, you're probably closing it wrong. They're offset in a specific way that make the rig look better when packed correctly. My V3 has the loop mounted on the bottom flap and the closing order is Bottom-Top-Right-Left. If you try to go BTLR, it looks horrible and the loop is much shorter. Can you post a pic of how the rig looks bad? With and without the main pin cover flap closed?"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
Di0 2 #3 May 16, 2014 Big Tits 'R' LovelyI'm standing on the edge With a vision in my head My body screams release me My dreams they must be fed... You're in flight. Quote Share this post Link to post Share on other sites
linebckr83 3 #4 May 16, 2014 I was told they were offset to put more tension on the closing loop once the pin is in. That way it is easier to close yet still takes force to open."Are you coming to the party? Oh I'm coming, but I won't be there!" Flying Hellfish #828 Dudist #52 Quote Share this post Link to post Share on other sites
tsalnukt 1 #5 May 16, 2014 I am aware of the proper sequence and I know that it's 'supposed' to make it look better. Beside making it look better why do it? There are a few manufacturers that place the grommets in the center of the flaps and they all seem to come out looking fine. It's not just one but most that i have put together recently. I guess I just dont' see how having the top and bottom grommets off set to one side can promote any sort of symmetry? Not to mention the extra strain on one side of the material. So I guess the better question would be....Besides trying to make the container look good does it actually serve any purpose?? Quote Share this post Link to post Share on other sites
theonlyski 8 #6 May 16, 2014 I remember reading somewhere that Bill B said it helps keep an even tension in the closing loop. I can't seem to find that though."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
sundevil777 102 #7 May 16, 2014 Quote promote any sort of symmetry? Symmetry is vastly overrated! Quote Not to mention the extra strain on one side of the material. There is no benefit to the symmetry that you think is essential, and no extra strain caused by this perceived asymmetry . Perhaps the "offset" as you see it is just how much each side flap extends toward the centerline of the rig-past the grommet. The position of the grommet with respect to the centerline is a design point that is independent of how much the flap extends past the position of the grommet. Maybe I'm not understanding your point, but when I noticed the same thing on my rig, I thought that it was evidence of a carefully thought out design instead of a problem.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
skydiverek 63 #8 May 17, 2014 http://www.hellotrade.com/united-parachute-technologies/main-closing-sequence-for-vector.html Quote Share this post Link to post Share on other sites
billbooth 10 #9 May 17, 2014 The first side flap you close pulls the top flap off-center in that direction, and the second side flap doesn't pull it back. If you close the side flaps in the numbered order, everything will end up centered. Quote Share this post Link to post Share on other sites
