degeneration
Serial numbers of Precision canopies - help!
The warning label is missing from a Xaos canopy I've got, so I'm wanting to know if the serial number is located any where else on the canopy, so I can source the other bits of info relating to it.
Also, side note: Should Xaos' have a metal ring at the bridle attachment point? Pic attached for what is there on the one I've got.
Thanks.
Sky Switches - Affordable stills camera tongue switches and conversion adaptors, supporting various brands of camera (Canon, Sony, Nikon, Panasonic).
All the Xaose canopies that I've seen had metal rings at the bridle attachment. You could easily get away with using a slink or a rapide link.
as far as the label - the older ones easily chewed off, Precision will replace them, but unless you know the SN, they'll put UNKNOWN on the new label. See attached.
