Merrick 0 #1 January 13, 2002 Just a quick question guys/gals... When trying to unzip an Access Application that I tried saving on floppy disk, before I reformatted my harddrive, I'm getting an "I/O error (Message WZ54) - Unable to read from Zip file."Anybody ever receive an error like this before, and if so, is there a fix for it?Thanks everyone!"Pammi's Hemp/Skydiving Jewelry" Quote Share this post Link to post Share on other sites
wildblue 7 #2 January 13, 2002 Try copying it to your hard drive, then opening and see what you get.If you still get errors, run scan disk with surface test on the floppy.I ain't happy, I'm feeling gladI got sunshine, in a bag Quote Share this post Link to post Share on other sites
Merrick 0 #3 January 14, 2002 Thanks Wildblue, but I'd already tried all that... It came up with 0 problems with the disk, and when I try to copy it to the harddrive I get an error "Cannot copy: The system cannot read from the specified device." So it won't even let me copy it. Shrug, who knows!Thanks again, anyone else!?"Pammi's Hemp/Skydiving Jewelry" Quote Share this post Link to post Share on other sites
wildblue 7 #4 January 14, 2002 K, if you can't even copy it to your drive, it's not a winzip problem.Try a different computer (to make sure it's not the drive you're using) or try a different disk in that drive.Try copying the disk, see if it'll let you do thatI ain't happy, I'm feeling gladI got sunshine, in a bag Quote Share this post Link to post Share on other sites
fonz 0 #5 January 14, 2002 Let me see if I get this right:The floppy itself checks out ok after a surface scan and all that.You can apparently cd to the floppy and do a DIR (or if you're afraid of DOS: "open" the floppy *rinse mouth*).But you cannot read the file or copy it.a) Try another computer. Floppies sometimes "malfunction" because drive heads are aligned slightly differently. I admit this is rare, but it can happen.b) Have you tried copying the entire floppy byte by byte and writing the raw image back to another floppy?Otherwise, it seems like the FAT may be screwed up. In which case recovering the file is likely to be hell.Alphonshttp://www.liacs.nl/~avwerven Quote Share this post Link to post Share on other sites
Merrick 0 #6 January 14, 2002 OK, I finally got the file copied to my harddrive... Ended up doing a dos diskcopy then copying the file from the other disk, so aparently there was a bad sector on that floppy..... However, I'm still gettting one of the same errors I was getting previously when I try to extract the application. (Error: Invalid compressed data to inflate.). Who knows. "Pammi's Hemp/Skydiving Jewelry" Quote Share this post Link to post Share on other sites
AggieDave 6 #7 January 14, 2002 Give me an old priest and a young priest...the power of Christ compels you...Thats how we fixed a NT problem once...Success is how high you bounce when you hit bottom.-General George Patton- Quote Share this post Link to post Share on other sites
fonz 0 #8 January 16, 2002 So what have we learnt from this?Floppies suck. They are slow, have very low capacity and are independable as well.Even considered getting a ZIPdrive or something similar?Alphonshttp://www.liacs.nl/~avwerven/skydive Quote Share this post Link to post Share on other sites
Pammi 0 #9 January 16, 2002 We've learned that WindowsME blows green donkey d***** and that we'll be going to XP as soon as I find that silly serial number.... ;)Closing pin jewelry Quote Share this post Link to post Share on other sites
fonz 0 #10 January 16, 2002 Quotegoing to XP as soon as I find that silly serial numberTssss! You need a serial number for that? Big Bill is watching you!Alphonshttp://www.liacs.nl/~avwerven/skydive Quote Share this post Link to post Share on other sites
wildblue 7 #11 January 16, 2002 "The Lord tells me that he can get me out of this mess, but he's pretty sure you're fucked. Hahaha!" I ain't happy, I'm feeling gladI got sunshine, in a bag Quote Share this post Link to post Share on other sites
Pammi 0 #12 January 17, 2002 Yeah, apparently...serial number, crack..whatever :)Closing pin jewelry Quote Share this post Link to post Share on other sites
