billvon
Safety note - pulling too high
What about spotting? Did you or someone talk to the spotter?
You've got a better chance of spotting them when you turn to start your track than from the aircraft.
So are you saying that there's little point in spotting from the aircraft, best to leave it until you start your track? Seems to me that its probably easier to avoid canopies, small aircraft etc by staying in the plane for a few more seconds, that waiting until you are closing on them at 120 mph?
The difference between stupidity and genius is that genius has its limits." -- Albert Einstein
Somehow I get the feeling that if the roles had been reversed you would have been screaming at HIM about exit separation.
Tell us about your load order. I assume that he was on an 8-way or larger formation skydive.
Points that came up later that weren't in your original post and need clarification regarding THIS situation:
1. Something about earlier jump run?
2. Flying back into jump run?
My reality and yours are quite different.
Somehow I get the feeling that if the roles had been reversed you would have been screaming at HIM about exit separation if you guys were on the same load.
Were you one separate jump runs over the same spot? Were you on the second which was 1/2 mile West of the first? Relate the jump run direction relative to the landing area.
You're post didn't provide very much info on exactly what happened to cause the near hit.
No, I'm saying that I estimate there's a snowball's chance in hell of spotting a canopy open 10k feet beneath you.
And yes it would make sense to look where you're going just as you track. I know I tend to clear my airspace for other skydivers on my own load but, we don't even have a good idea of our true trajectories thanks to the relative cues we get starting a track, I expect you would start looking down then out at about 45 degrees as you build speed, but I sure don't do that. Maybe I should, frankly I'd rather the DZ managed the job of mitigating the risk, there's only so much shit I can look out for at one time.
I think this is the key, he was on another load in an different aircraft. He pulled high and was still under canopy when Bill tracked past him at 3k.
Talk about turning loads. :)
> So you are telling me that everyone at your DZ is pulling at 3000 - 2000 feet.
No, I'm telling you that at least one jumper did not and almost killed me this weekend. Fortunately, most people at Perris _do_ pull at those altitudes (or take precautions, like doing a hop and pop at 6000 or exiting in the CRW area.)
You weren't nearly killed because a guy opened at 3500, or remotely close. He was at that altitude 5 minutes after exiting, suggesting he was at 7k or beyond. You're blurring the message when talking about this 2-3k thing.
But the guy was allegedly on another 8-way. I'm a bit incredulous that anyone on an 8-way deployed at 7k or anywhere near it, never mind allowing for breakoff. Something doesn't add up.
I did a high pull meester bill at perris and got the briefing of all briefings on where I was supposed to be until what altitude....
they were like dont even think of crossing this road until you are at like 2000 feet
and I listened
Dave
http://www.skyjunky.com
CSpenceFLY - I can't believe the number of people willing to bet their life on someone else doing the right thing.
You might want to go reread the post. Nowhere is it stated that the guy was on another 8 way. :S
Thanks for the additional input.
So a few questions remain....
Was Bill's load the same jump run or the offset to the West?
Did the guy fly over into the Bill's space or did Bill track over into HIS space?
If different jump runs on different tracks, which one was upwind of the other or were they parallel to wind direction?
Which load was closer to the landing area?
Ahh, thanks, I missinterpreted the first line of the first post. The whole thing makes more sense now.
At most multiple-aircraft DZ's the opening altitudes are between 2000 and 3000 feet
At the WFFC, per the 06 stuff anyway and I quote
"You need to plan your deployment altitude so that you have a fully open canopy no higher than 3000 feet AGL, and you are expected to be familiar with the opening characteristics of the canopy you will jumping in order to do this."
Course they also stated;
Hook turns (turns more than 90 degrees to landing) are permitted only in the swoop pond hook turn area!!! Hook turns are extremely dangerous at the Convention and must not be done where they are not expected.
Then again, I saw a lot of people breaking these rules, and no one said a thing....
hmmm.....
The FAA is often called the 'tombstone agency' for this reason. They are slow to act and fix problems that are relatively well known until the body count climbs....
Maybe the USPA is trying to vie for that moniker.
_justin
