DBTECH
FAA NOTAM--VFR GO!!
Effective--9-19-01 21:00 EDT
FDC 1/0224
ATTENTION ALL OPERATORS - SPECIAL NOTICE EFFECTIVE IMMEDIATELY UNTIL FURTHER NOTICE. PURSUANT TO 14 CFR 91.139 (EMERGENCY AIR TRAFFIC RULES), PART 91 IFR AND VFR AIRCRAFT OPERATION ARE AUTHORIZED AS SPECIFIED IN NOTAMS 1/0111 AND 1/0112. [0111 and 0112 are identical--ed.] TO THE EXTENT THAT CONTRARY LANGUAGE EXISTS, THIS NOTAM SHALL SUPERCEDE.
NOTE: FOR PURPOSES OF THIS NOTAM, THE "TERRITORIAL AIRSPACE OF THE U.S." MEANS THE AIRSPACE OVER THE U.S., ITS TERRITORIES AND POSSESSIONS AND THE AIRSPACE OVERLYING THE WATERS BETWEEN THE U.S. COAST AND 12 NAUTICAL MILES FROM THE U.S. COAST.
NOTE: FOR PURPOSES OF THIS NOTAM, AN OVERFLIGHT MEANS THE AIRCRAFT TAKES OFF FROM AND LANDS AT LOCATIONS OUTSIDE THE U.S., ITS TERRITORIES OR POSSESSIONS BUT ENROUTE TRANSITS THE TERRITORIAL AIRSPACE OF THE U.S. WITHOUT LANDING IN THE U.S., ITS TERRITORIES OR POSSESSIONS.
NOTE: FOR THE PURPOSES OF THIS NOTAM, "ENHANCED CLASS B AIRSPACE" IS DEFINED AS THAT AIRSPACE WITHIN THE EXTREME LATERAL LIMIT OF CLASS B AIRPACE FROM SURFACE TO INFINITY (I.E. SUCH OPERATIONS ARE NOT AUTHORIZED WITHIN, BELOW, OR ABOVE CLASS B AIRSPACE):
PART I. EXCEPT FOR THE OPERATIONS LISTED BELOW, PART 91 VFR OPERATION ARE PERMITTED WITHIN THE TERRITORIAL AIRSPACE OF THE U.S., FOR U.S. REGISTERED AIRCRAFT PROVIDED THAT THOSE OPERATIONS ARE CONDUCTED OUTSIDE "ENHANCED CLASS B AIRSPACE."
THE FOLLOWING TYPES OF OPERATIONS ARE NOT AUTHORIZED:
CIVIL AIRCRAFT VFR FLIGHT TRAINING OPERATIONS
BANNER TOWING OPERATIONS
SIGHT SEEING FLIGHT OPERATIONS CONDUCTED FOR COMPENSATION OR HIRE (UNDER PART 91, PURSUANT TO THE EXCEPTION IN 119.1(e)(2))
TRAFFIC WATCH FLIGHT OPERATIONS
AIRSHIP/BLIMP OPERATIONS
NEWS REPORTING OPERATIONS
EXAMPLES OF AUTHORIZED OPERATIONS, OUTSIDE "ENHANCED CLASS B AIRSPACE" INCLUDE:
AIRCRAFT MAINTENANCE REPOSITIONING.
BALLOONS.
CIVIL AIR PATROL.
GLIDERS.
MANUFACTURER PRODUCTION FLIGHT TESTS.
MAPPING/PHOTOGRAPHY MISSIONS.
PIPELINE/POWERLINE INSPECTIONS.
SEAPLANES.
SKYDIVING :)ULTRALIGHTS.
WILDLIFE MANAGEMENT OPERATIONS.
