Akegata 0
The only thing I can say about it is that I am assuming that in 10 years time every manufacturer will provide stowless bags as default, and everyone will wonder why the hell people used ~8 rubbed bands on their bags for so long.
mxk 1
I ordered it with some apprehension because V358 is the biggest container that supports the semi-stowless bag, Spectre 230 is already listed as full-fitting, and I've added Dacron lines to that. Everyone I asked, including people at UPT (with Skydivesg's help) and on this forum, said that the combination should be fine. The first time I packed it, I could see that the bag will not work. A fact later confirmed by Kenneth Gajda @ UPT. Dacron lines add too much bulk in the pocket (the tabs have trouble staying closed), and the big main causes the whole thing to be more of a ball shape that just wants to pop out of the container. There is nowhere near enough friction to keep it in and the dynamic corners do not help either.
I replaced the bag with a regular one and couldn't be happier. Personally, I wouldn't recommend a semi-stowless bag for mains above 200 sqft. You only have two locking stows and those made me a bit uncomfortable thinking about what would happen if one breaks just after bag extraction. This may be a non-issue, but for a big main I prefer having 4 locking stows. Having the lines exposed and facing the BOC also greatly improved the overall fit. Packing time is a matter of practice, but I doubt that a semi-stowless bag would save me more than minute.
I replace about 1-3 rubber bands every 10-15 jumps at the first sign of wear (before they break!). Large bands for locking stows, small ones for the rest, singe stows with 3" bights that provide 6-10 lbs of extraction force (I know PD recommends 8-12, but couldn't get that with other configurations). I keep spare non-locking bands attached, so I never have to replace a rubber band in the middle of the day. Also, not all rubber bands are created equal. My DZ provides them for free, but I found their small bands to be weaker than the Keener ones I buy from ParaGear or ChutingStar.
RMURRAY 1
AkegataI got a semi stowless bag for my Vector 350 about 70 jumps ago.
for security and orderly payout of the lines. for example if the pilot chute hesitates with the bag out of the container, the lines are still in control. I am not sold yet but may be in 10 year...I find easier and faster to pack with rubber bands.
mxkPersonally, I wouldn't recommend a semi-stowless bag for mains above 200 sqft. You only have two locking stows and those made me a bit uncomfortable thinking about what would happen if one breaks just after bag extraction. This may be a non-issue, but for a big main I prefer having 4 locking stows.
And this is absolutely valid - I'm not challenging your comfort level in any sense but rather just adding my own experience; I too am a bigger guy and with a larger main, a 210 Spectre on microline. I jump one of Jerry Baumchen's NoStoBags. Not long ago I was in a two-out situation and the locking stows did keep the main in the bag. However, I DID replace them immediately prior to the jump so they couldn't have been in stronger shape. I use larger bands and double-stow. Surely, had one or both of those stows not held it would have been a much more interesting two-out.
![[:/] [:/]](/uploads/emoticons/dry.png)
I am wondering now IF the mass of larger canopies in a semi-stowless makes them more susceptible to out of sequence deploymentsas opposed to smaller wings. Anyone have a thought on this?
JerryBaumchen 1,421
Hi mxk,
QuoteDacron-lined Spectre 230
I recently built a NoStoBag for a 230 canopy. I added a 3rd grommet so that the owner had a choice of using 2 or 3 rubber bands to keep the canopy portion of the bag closed.
Since my 3-sided line stow pouch is on the bottom side customers do not have a problem with lines bulging out of the sides; at least no one has told me that they are having any problems ( fingers crossed ).
Just sayin',
Jerry Baumchen
Hellis 0
RMURRAY***I got a semi stowless bag for my Vector 350 about 70 jumps ago.
In my opinion what you describe here is the opposit of a rubberband bag.
Each time a rubberband release lines you get a rocking motion on the bag, slack in the lines, lines shaking from side to side.
Is that orderly payout?
With semi/stowless bags all the lines come out in the center without shaking the whole system.
Security?
If rubberbands would never break I would agree with you.
But because they do it can easily create a linedump.
....But you have to replace them in time!
Sometimes they have gone on the first jump for me. And that is not sequrity in my opinion.
sundevil777 102
QuoteSecurity?
I agree, that is why I don't use rubberbands for the critical locking stows. The non-locking stows breaking isn't a big deal, but the canopy dump from broken locking stows is. Something much less likely to break is better such as tube stows.
I'm not familiar with the "locking" method of the stowless bags. Are they not vulnerable to failure?
Hellis 0
sundevil777QuoteSecurity?
They probably are, but I have never had any issues.
Mine is held shut with 4x3 magnets.
I feel confident it stays closed since my canopy is smaler than the bag. If it would be the other way around, I would not jump it.
