xijonix 0 #1 July 1, 2015 Hey all, I've put my last 400 jump on SA2-170s and 150s and I'm trying to decide on what canopies I should demo for my next one. I definitely want to get further into high performance landing so I'm thinking looking at a stiletto, katana, or something similar. I'm currently doing mostly double front approaches but I want something that I can spend a good number of jumps under and get the most out of its performance potential. Should I consider a smaller sabre 2 like a 135 or should I find a higher performance 150ish. Quote Share this post Link to post Share on other sites
piisfish 140 #2 July 1, 2015 depending on wingloading I would personnally go for same type, smaller size.scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
Deimian 43 #3 July 1, 2015 xijonixHey all, I've put my last 400 jump on SA2-170s and 150s and I'm trying to decide on what canopies I should demo for my next one. I definitely want to get further into high performance landing so I'm thinking looking at a stiletto, katana, or something similar. I'm currently doing mostly double front approaches but I want something that I can spend a good number of jumps under and get the most out of its performance potential. Should I consider a smaller sabre 2 like a 135 or should I find a higher performance 150ish. For swooping I would say that Sabres are better than Stilettos. Sure, Stilettos can be snappier on turns, but the recovery arc is shorter AFAIK. People have been doing awesome swoops with Sabres, so I would go down that road. Katanas are better when highly loaded (or so I've read, I've never flown them), and are quite ground hungry, so I wouldn't consider them if I am not 100% sure. Crossfires can be something in between, with longer recovery arc than Stilettos, but not as aggressive as Katanas, and with a little bit more responsiveness than Sabres. There are also other manufacturers with good canopies (I've heard good things about Nitrons or Magellans for instance) that you might consider. I have less jumps than you, so don't consider my post too seriously, others with more experience will chip in. Quote Share this post Link to post Share on other sites
fcajump 164 #4 July 1, 2015 If you haven't watched it yet, check out John Leblanc's presentation to the BPA... https://www.youtube.com/watch?v=eK2_yQ_A9Fc Might give you some insight as well. JWAlways remember that some clouds are harder than others... Quote Share this post Link to post Share on other sites
shift 0 #5 July 1, 2015 My opinion, take it for what its worth. If you are just starting, start on your current canopy (sabre2 150?). Sabre2's have pretty long recovery arcs. Not as long as a Katana but more than a Stiletto. I started double fronts on a Storm 190, then carving 90's on a Sabre2 170, then Sabre2 150. Now I'm working on 180's, and will be moving on to a Katana 150 before a Katana 135. After jumping the Katana 150, I'm glad I started on my less aggressive Sabre2. But, as said, you can get pretty decent swoops out of one all things considered. PS I hate Stilettos for swooping. The short recovery arc may prevent you from hitting as hard if you mess up, but you have to start your turn really low. Quote Share this post Link to post Share on other sites
yoink 321 #6 July 1, 2015 Might want to update your profile there. Quote Share this post Link to post Share on other sites
OzzieDave 1 #7 July 1, 2015 right tool for the job. Not advocating downsizing or changing platforms to something that you are not ready for but consider your goals, current skills and landings and the next steps in your progression and choose the right canopy. You can wingsuit with a Katana but that isn't seen as a wise canopy selection. You can bust big turns on Sabres/Pilots/Saffires but that wasn't what they were designed for. 0.02c Quote Share this post Link to post Share on other sites
Pobrause 6 #8 July 1, 2015 assuming your profile is correct and up to date I personaly don't see any reason for you to downsize. The Sabre is hands down THE perfect choice for somebody wanting to get started in swooping. Its recovery is quite long compared to Stiletto/Pilot/Safire its range on rears is remarkable for an intermediate canopy you need to be very consistent to pull off nice swoops which is a very good thing to learn BEFORE you get on higher performance wings It does have very good bail out capabilities if flown correctly swoops like crazy https://www.youtube.com/watch?v=MISV7GXi7qc https://www.youtube.com/watch?v=25aExv7YDYg I loaded my Sabre 150 also close to 1.4 and got consistent 80+ meter swoops on low wind days doing 270s from 185m (~610 ft) The Sabre is a very capable canopy and in my opinion pretty close performancewise to a Crossfire. At least the recovery arch is not that different, range on rears I think the SA2 wins Why only double fronts on the 150? Have you tried 90/180/270s up high? Have you tried bringing them down to the ground on the 150? Do you use your rears, do you know what they are capable of? Do you have any idea of the 'performance potential' of your current canopy? You sound like you could use some coaching instead of a new canopy If you want to explore a new sea, why using a new ship you are not familiar with instead of the old and proven one that is equally capable? if you're not swooping the shit out of your sabre please don't even consider a Katana. Xfires might be just a small step, Katanas are a completely different level (or at least can be flown at). And IMHO 100 jumps a year are nowhere near enough to either jump a Katana or start serious swooping------------------------------------------------------- To absent friends Quote Share this post Link to post Share on other sites
Jiggs 0 #9 July 6, 2015 To the OP: Kudos for taking the time to ask the question. Talk it through with a qualified canopy coach, go through your current landings and goals ( as well as currency, training plan, etc) to determine what the best approach will be. This way you can get a view on what a potential progression looks like, timing and the ability to improve your skills. There is definitely a limit of what you can “safely” achieve with a Sabre 2 – particularly the sizes that you are talking about. You sound like you have a long way to go before you max out your current wing so the answer might not be what you expect For what it is worth: Stay on same canopy but get coaching Then downsize same canopy Then maybe change canopy type Pobrause: Good info – but; Are you saying you swoop 80+ metres with gates into wind at a WL of 1.4? Or you are using a very different way of measuring swoop distance"Don't blame malice for what stupidity can explain." "In our sleep, pain that cannot forget falls drop by drop upon the heart and in our despair, against our will comes wisdom" - Aeschylus Quote Share this post Link to post Share on other sites
