lyosha 50 #1 October 14, 2015 Is black hardware made of a black metal or just coated with something? Can someone post the wear on the hardware after a few hundred jumps? Is it more abrasive to the white loop on the risers? Quote Share this post Link to post Share on other sites
riggerrob 643 #2 October 14, 2015 Ask DJ Associates. It looks like regular carbon steel with a durable matte black coating. The black coating is more durable than the cadmium-plating on MIL SPEC hardware. Quote Share this post Link to post Share on other sites
Remster 30 #3 October 15, 2015 The black coating used on the RI rig I have has lasted two years with no marks.Remster Quote Share this post Link to post Share on other sites
Squeak 17 #4 October 16, 2015 RemsterThe black coating used on the RI rig I have has lasted two years with no marks. Is it a hard anodising?You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
lyosha 50 #5 October 16, 2015 RemsterThe black coating used on the RI rig I have has lasted two years with no marks. Really? That's encouraging. Anyone with an infinity with black hardware that's seen some action already? Quote Share this post Link to post Share on other sites
diablopilot 2 #6 October 16, 2015 I put a couple thousand skydives on an infinity with black hardware with no noticeable wear.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
Skydivesg 7 #7 October 16, 2015 lyoshaIs black hardware made of a black metal or just coated with something? Can someone post the wear on the hardware after a few hundred jumps? Is it more abrasive to the white loop on the risers? 400 jumps on my Vector - still looks great - no obvious wear.Be the canopy pilot you want that other guy to be. Quote Share this post Link to post Share on other sites
theplummeter 15 #8 October 16, 2015 lyosha***The black coating used on the RI rig I have has lasted two years with no marks. Really? That's encouraging. Anyone with an infinity with black hardware that's seen some action already? I believe that Velocity - like Rigging Innovations - uses Wichard for black hardware. Other manufacturers may use them as well. Quote Share this post Link to post Share on other sites
dpreguy 14 #9 October 16, 2015 I think anodizing colors is only for aluminum. Other processes are used for ferrous metals. Quote Share this post Link to post Share on other sites
sundevil777 102 #10 October 16, 2015 I don't think corrosion resistant steel (aka stainless steel) is considered a ferrous metal. People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
hackish 8 #11 October 16, 2015 sundevil777 I don't think corrosion resistant steel (aka stainless steel) is considered a ferrous metal. dpreguy is correct in that you cannot anodize steel or stainless. Technically if it has iron in it then it's a ferrous class of metal. The black coating is black oxide. I think for us it would be stainless hardware that's been coated. You can't just do it on zinc coated hardware so stripping then coating is a bad deal. The black oxide application itself uses a salt not an acid so hydrogen embrittlement is not an issue. I did some of my own anodizing and oxide coating non-parachuting parts I made/machined but I gave up a few years ago as it was a messy and difficult process. Nobody wants their parts to come out blotchy! -Michael Quote Share this post Link to post Share on other sites
