Jethers203 0 #26 June 14, 2016 That's awesome info Phree. Thanks. Quote Share this post Link to post Share on other sites
Jethers203 0 #27 June 14, 2016 So, I jumped my setup Saturday and Sunday. Saturday: Went to 10,000' and took it down to 8,000' to test the bag and extra weight in freefall. All went well, but the opening was a little snappy. After checking connections and cutaway system, I deployed the flag by lowering the 10 lbs of lead shot attached to the bottom of the leading edge. It was apparent right away that the weight was not sufficient. I hooked my feet behind the top connection and put some forward pressure on it. This helped a lot and I could feel what the flag was doing a lot better. It flew great in breaks and deep breaks, but not so much in full flight. My Spectre 190 at 1.33 is a bit too fast for this setup. I chose to land on an asphault road bordering the landing area in order to limit the dirt exposure to the flag. I setup on final 150+ yards out and took it straight it. Landing was smooth. Sunday: Went to 5,000' and opened right out the door. Checked connections and deployed the flag. I added 5 lbs (6,000 BB's) to the middle of the flag and could tell the difference right away. It flew a lot smoother in breaks and very smooth in deep breaks. Full flight was still a bit too fast. I landed near the peas in the landing area this time. Landing was smooth. Attached are a few pics. Cloudy ones from Saturday and sunny ones from Sunday. I still intend to put the weight in 2" tubular nylon along the leading edge. Any feedback is appreciated. Clint Quote Share this post Link to post Share on other sites
ByMike 0 #28 June 14, 2016 Feedback or not but... In Sweden we could´t jump flags with weights because of fear of accidents (was one incident like 20+ years ago) But we just worked around that by not using solid weights or ledd (bad for the environment if cut away) and using sand and a nifty cut-a-way/release system for the sand do spread in mid air instead. Yes it´s a lot bulkier but was the only way to make i possible again. And from my experience is that you need more weights than one think.... =) Quote Share this post Link to post Share on other sites
