Tom794 0 #1 June 24, 2016 Hi everyone! Just chasing some advice about fitting an Atair Radical 135 into my Wings W8 container. My current main is a 140 (tight fit but manageable), however I've been informed that the Atair canopies pack larger, and also contain more material due to the end cells being divided into 3 sections, as opposed to the standard 2. From what I can find, the pack volume of the Radical 135 is 330 cubic inches... but I can't find any numbers to use for reference for the container. Any help is appreciated! Cheers,Tom. Quote Share this post Link to post Share on other sites
BKS60 0 #2 June 24, 2016 Had a similar question a few years ago. If you contact Wings with the rigs serial number they can tell you what canopy it was originally sized for and then you can look up the pack volume specs of that canopy. Hope this helps."You don't get many warnings in this sport before you get damaged" Quote Share this post Link to post Share on other sites
coticj 0 #3 June 28, 2016 It depends on which material you have on your Radical. Pre 2008 were pretty thick. But if you had a 140 I think it shouldn't be a problem now.http://www.prostipad.si Quote Share this post Link to post Share on other sites
justme12001 0 #4 July 1, 2016 I jump a wings W10, and a radical 135 made from galvinar(SP) fit just fine. I actually use a W8 main d-bag most of the time and the 135 fits in it fine. I have two mains that I switch back a forth between, so I have the W10 bag and the W8 bag, very little difference in the two. As a side note, yes the radical does pack slightly larger, but since the galvinar is kind of "sticky" it is easier to man handle into the bag....if that makes any sense. Quote Share this post Link to post Share on other sites
