cl0wn 0 #1 July 1, 2016 I have a Wings W-9 harness with articulation, which fits me pretty well. I'm learning to freefly, mainly back-flying so far. I'd like to try sit-flying, and I noticed that the container can slide up an inch or two if you push it up from the bottom. Is it ok or it can be an issue for sit-flying? Quote Share this post Link to post Share on other sites
riggerrob 643 #2 July 1, 2016 First: ask a local rigger to inspect your harness and confirm how well it fits you. Second: ask your local rigger if a butt bungee will help with fit. Third: if you complete your profile, we can help introduce you to local riggers. Quote Share this post Link to post Share on other sites
sundevil777 102 #3 July 2, 2016 A bungee might help with keeping the legs traps in position, but it is far from a positive fix for the very real danger. At the end Jan Meyer's Attached article (in the linked post below). Is a simple and most important, effective way to add a strap similar to what tandem passenger harnesses now have: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4219062#4219062People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
HapHazard 0 #4 July 2, 2016 cl0wnI'm learning to freefly, mainly back-flying so far. I'd like to try sit-flying, and I noticed that the container can slide up an inch or two if you push it up from the bottom. Is it ok or it can be an issue for sit-flying? An inch or two is nothing to worry about. Heck, that's less movement than most rigs experience. Quote Share this post Link to post Share on other sites
