pchapman 279 #1 February 9, 2017 The performance of pilot chutes has come up from time to time here. I came across this link - Some pilot pilot chute testing in a horizontal tunnel in Oshawa, Ontario by Matt G, Will Kitto, & Martin Tilley, behind a wingsuit. They used standard, toroidal, and midskirt vented designs. The focus is on BASE but it is interesting testing in any case. http://base-book.com/pc-extraction-and-inflation Quote Share this post Link to post Share on other sites
erdnarob 1 #2 February 18, 2017 Hello Peter Have you tried to test a reserve pilot chute in a vertical wind tunel ? This is what I would like to do. The set up should be quite easy since the wind tunel operator can vary the speed which is seen on a display screen from inside. This is what I had in mind to do so : What it takes is somebody recording the speed and force (with a suitable dynamometer measuring up to 200 lbs). 5 points (speed and force) should be enough to draw a graph. This set up would be near the reality of the free fall. The pilot chute can be attached to the bottom screen. I have talked to SkyVenture officials in Montreal. Their fear is to get something giving up and hit the fan propeller at the top. They told me that even a 25 cents loose coin can badly damage the fan. Maybe if I show them a set up well designed, they would let me do it. The problem is to borrow a suitable dynamometer. Personally I think there will be less chance in such a set up to get something loose than what can happen having several people flying inside with shoes, googles, helmet, piece of clothes...etc What do you think ?Learn from others mistakes, you will never live long enough to make them all. Quote Share this post Link to post Share on other sites
Hooknswoop 19 #3 February 19, 2017 QuoteHave you tried to test a reserve pilot chute in a vertical wind tunel ? I have. About a dozen of them. Changed the way i think about reserve pilot chutes. Initially, I agreed with your idea, the Pc that pulls the hardest wins. After watching the wind speed come up with 2 PC's attached to the net, I completely changed my thinking. The first PC to inflate wins. I have video somewhere. Derek V Quote Share this post Link to post Share on other sites
erdnarob 1 #4 February 21, 2017 Hello Hooknswoop Thanks for your message. Of course you need a fast PC inflation but you also need enough force to extract your reserve from its tray. 1) Do you have any figure about speed versus force for a specific PC ? 2) What is the highest PC force you have seen at 120 mph ? ThanksLearn from others mistakes, you will never live long enough to make them all. Quote Share this post Link to post Share on other sites
JerryBaumchen 1,371 #5 February 22, 2017 Hi Derek, QuoteAbout a dozen of them. QuoteThe first PC to inflate wins. Since my pilot chute was one of those tested and I have a copy of the results, my belief is that total pulling power is also very important. While you may give 'first to inflate' your best consideration, I believe that both are very important as regards total deployment times. PIA did some testing recently of pilot chutes & extraction forces. I have seen one video that shows the bag beginning to come up & out of the container before the pilot chute is completely inflated & before the bridle is taut. My conclusion is that the drag on the two items was enough to get the bag out of the container. Just my $0.02 on this, Jerry Baumchen ETA: This is a dumb statement: 'My conclusion is that the drag on the two items was enough to get the bag out of the container.' Of course, there is enough drag. What I meant to say is: 'My conclusion is that there was sufficient drag, without the pilot chute being totally inflated, to get the bag out of the container.' Sorry. Quote Share this post Link to post Share on other sites
